Results 241 to 250 of 795
BANNED BANNED BANNED
- Sep 2015
- 13,919
January 3rd, 2022 02:02 AM #241
at dapat interviewhin may-ari ano ginawa nya at ihighlight eh hindi binigyan airtime. Hoootaena mga news walang kafuture-future gusto ibalita mga nasalanta / gutom . Eh lagi na lang nangyayari sa pinas yan not anymore bago. Magbalita naman ano gagawin paano prevention. Parang veerus sino matitibay na nilalang!!!!
again sa ba kasi grumadweyt????
January 3rd, 2022 02:13 AM #242
Seen similarly built structures adjacent to each other. 1 totally gone, the other unscathed. The difference? Design, Specs, Execution, Material (quality/standards/gauge/even brand). The basics, they all matter.
Sent from my SM-G970F using Tsikot Forums mobile app
January 4th, 2022 12:59 PM #243
Please give suggestion on water pump / pressure tank system ... Planning to connect water pump to water tank then to pressure tank ... what's a good brand and estimated cost ...
Eurostar(?) made in Italy 3/4 or 1 HP water pump
40 or 60 liter Italian pressure tank
Water level switch so pump turns off if there's no water supply
January 4th, 2022 03:02 PM #245
Have had no problems w/ Pentair's WellMate bladder type pressure tanks. They retain pressure long w/ air pressure checks far between. The shell won't corrode, too.
Float or rod level switches, lots available & they all work fine. The rod level ones have no moving parts & work really well except when your water is on the hard side...would need periodic cleaning.
Pumps, go for those w/ good support & parts. Goulds or Grundfos. If you intend to hook hobo, get 2 identical ones to relieve you of downtime misery once they conk out....& they all conk out. The good ones just would serve you longer & have better chances of resurrection.
January 4th, 2022 03:16 PM #246
Pano ba ang right way to 'bleed' the water or air out of the steel pressure tank para mas matagal maintain water pressure?
Signature
January 4th, 2022 03:22 PM #247
Long given up on those stainless pressure tanks. When your pump turns on & off at short intervals(very bad for pumps), drain the water off the PTank to refill itself w/ air. You won't have this problem w/ bladdered ones like WellMate.
January 4th, 2022 03:29 PM #248
Gumamit ako once ng bladder tank, from Bestank din yata. nagkaleak yung bladder after a while, parang less than 2yrs. Kaya balik SS pressure tank ako.
Signature
January 4th, 2022 03:42 PM #249
Not all tanks are created equal, sir.
January 4th, 2022 04:22 PM #250
Also, ano ba ang tamang pressure ng bladder tank before lagyan ng tubig?
Signature
We previously supported Tapatalk for Google Play and iOS store, but both are unsupported right now....
tapatalk smart phone application.
