Should there a water supply switch between the water tank and water pump? ...
You'll need a a float switch(to safeguard the pump if tank runs out w/ water), a manual pump switch(magnetic or breaker) & a valve from tank to pump. The latter 2 are necessary for servicing/replacing the pump, as doc advised above.
An added note, for some reason(orgasmic alarm pheromones perhaps?[emoji848]), ants love to gather around outlets & pressure switches. Contact can be compromised. Inspect & debug these periodically.
Sent from my SM-G970F using Tsikot Forums mobile app
