Page 379 of 404 FirstFirst ... 279329369375376377378379380381382383389 ... LastLast
Results 7,561 to 7,580 of 8077
    #7561
    Dalawa pa lang naman ang generation ng starex. 1st Gen, 1997-2007 / 2nd Gen 2007 - present.
    Jul 2003
    #7562
    ATF PREMIUM HTP | Petron
    Mag pa ATF exchanger ako sa Petron marcos hiway. sana available yaan ATF premium HTP.
    kung saan san ako nag hahanap ng Red-1 (pero bakit Red 1-"K")
    At wary ako bakit "suitable" ang description at hindi exceeds or meets
    Sana ok quality nito.
    Apr 2012
    #7563
    Quote Originally Posted by kurt View Post
    Magkano isa?
    Sent from my SM-J730G using Tapatalk
    Jul 2003
    #7564
    Php281/liter ATF HPF, 215 ordinary
    1300 labor
    para sa ATF exchanger / dialysis, pa kwento po ng procedure.
    pinakita ko ang manual saying 10 liters ang ATF capacity ng A2.5 engine ng GS VGT.
    puzzled sila kasi 5 liter lang daw nilalagay nila. after ma flush using 5 or so liters din...????
    pag drain ba nang atf exchange machine (after cleaning, flushing at before ilagay ang fresh ATF)
    0.00 ZERO Liters ba ang laman ng AT transmission or may laman ng XXX liters?
    sabi nila isang paraan is sukatin kung ilan liters nilabas ng transmission, e di ba parang drain lang sa plug yuu na may maiiwan sa looban ng transmission?
    kung parang gravity drain lang -- safe ba to assume yun naiwan na ATF sa loob ay clean and fresh na rin kaya 5-6liter lang isalin na fresh ATF to complete the 10 liters ATF capacity?
    so ilan liters ba ilalagay na fresh ATF after cleaning?
    in absence of dipstick may sukatan ba like a bubble window?
    thanks
    marami naiiwan sa loob especially sa mismong torque converter. most transmissions have a level overflow hole... this prevents overfilling
    Jul 2003
    #7566
    Flushed using 4liters. Clean red na itsura.
    Put back 5.5 liters as final fill.
    Sabi ng operator, Atf exchanger did not drain-higop the torque converter but it was flushed with clean atf. So naiwan na atf is 4-5 liters and as clean as the fresh open bottles na additional 5 liters to complete the 10 liter ATF capacity.
    I hope that Red-1 rating is true.
    Plan to use this petron atf maybe 20-25k kms just to be safe.
    Apr 2012
    #7567
    May nagpalit na ba ng shock absorbers dito? Magkano inabot?
    Apr 2006
    #7568
    Go to Fronte motors in Kabignayan cor. Banawe. Original would be around 3.5k and replacement would be around 1.8K. Not sure if this is still the price today. This is what the mechanic there told me when I had to change my bushings.
    #7569
    Better get OEM shock absorbers. Baka mag-iba kasi ang ride kapag replacements ang kinabit. Ganda pa naman ride ng Grand Starex.
    Apr 2012
    #7570
    May orig kasi, meron din yung Mando na OEM part din ng Hyundai. Mas mahal ng 1,500 yung orig
    Apr 2012
    #7571
    Talaga ba minsan pag matagal na remove battery parang hirap sa shifting yung tranny na matic?
    Sep 2018
    #7572
    Help. Totoo po ba yung steering problems sa elantra? May balak po kasi akong bilin na 2012 elantra.
    #7573
    Quote Originally Posted by alexatl19 View Post
    Wrong forum, dude.
    #7574
    The TCM memorizes the driving style and shfts accordingly. When the battery is removed (in my experiemce about 15 minutes or more) this stored memory is erased and the TCM is reset to factory settings - slower to downshift. So after you remove the battery it will relearn again your driving style and changes its setting depending on how you step on the accelerator.
    Apr 2012
    #7575
    The TCM memorizes the driving style and shfts accordingly. When the battery is removed (in my experiemce about 15 minutes or more) this stored memory is erased and the TCM is reset to factory settings - slower to downshift. So after you remove the battery it will relearn again your driving style and changes accordingly.
    Yes nakapag adjust naman na siya. Di na siya parang hirap lalo pag paahon. [emoji16]
    Apr 2012
    #7576
    Got new tires and Kumho Portran KC53 ulit kinuha ko.
    Made in Vietnam siya compared sa naunang sets ko na Kumho na Made in Korea
    #7577
    Does anyone need a new battery? Motolite belatedly replaced my 3SMF Gold. Already bought a replacement last month.
    genereso! is that your middle name?
    #7579
    Free? Hehehe..how much?
    #7580
    Actually thinking of selling my brand new(ish) 1 month old Motolite and installing the replacement for the old one with 6 months warranty left. Hmmm. Ok na ba 5k? Was sold to me for 6.6k. Or I could just use this for my truck.
2008 Hyundai Starex (Gen. 4)
