Page 404 of 404 FirstFirst ... 304354394400401402403404
Results 8,061 to 8,077 of 8077
    Mar 2004
    #8061
    Check fuel filter again ... might as well check fuel pump ...
    Jan 2008
    #8062
    try mo muna pa scan, baka may stored codes yan to check.. yung sa kia carens ng tropa hindi naka ilaw yung check engine, pero pag scan may stored code na faulty crankshaft position sensor..
    nung palitan ng crankshaft position sensor, ganun pa din ang error.. yung mechanic sa kia, pinabaklas yung injection pump tapos dinala pa sa bosch service center..
    after ganun pa din problem, ayaw mag start ng ayos tapos mausok pag umandar..
    dinala sa mekaniko ko, nag trace sya ng error.. wala makita tapos pina scan nya ulit sa iba naman, crankshaft position sensor pa din..
    ginawa bumili ulit ng isa pang sensor.. ayun umayos na.. it turns out sira din yung isang binili kahit brand new
    #8063
    thanks sir, try ko palitan fuel pump bukas.
    #8064
    napa scan ko na po, walang error/stored code na lumabas. nalinis na din maf sensor, same problem pa din.
    Jan 2008
    #8065
    have you checked yung suction control valve? nasa main fuel pump yan..
    #8066
    ok naman yung inlet metering valve, normal naman yung sasakyan kapag naka idle, matining pa yung makina, one click lang pagstart ng engine sa umaga. problema lang talaga pag pinatakbo na yung sasakyan ilang seconds lang bigla na sya mag low power, ayaw tumaas sa 2000rpm parang hesitant na mag-move forward, tapos mausok kapag pipilitin tapakan accelerator, after few minutes ok ulit sya pero magbubuga muna maitim na usok.
    Dec 2002
    #8067
    Quote Originally Posted by mike18 View Post
    check your turbo hoses. baka may hose na maluwag. all the hoses from the turbo to the intercooler and to the engine intake manifold. pag may isang maluwag dyan hindi talaga makakabirit yan.
    re black smoke, sign na kapos sa hangin. since walang error code, pag hindi turbo hoses yan, e baka turbo na. may mga binebentang starex crdi vgt turbo cartridges sa carousell.
    black smoke ha hindi gray? pag gray baka barado dpf mo. how is your driving routine? baka pure city, walang highway? you may need to burn out your dpf.
    #8068
    Quote Originally Posted by yebo8 View Post
    nacheck ko na mga turbo hoses at fittings, ok naman walang maluwag at walang oil leak, pinacheck ko na din sa mekaniko yung turbo at egr nung pinalinis ko last week, ok din naman good pa naman. nalinis ko na din yung MAF sensor.
    nagtroubleshoot ako kagabi, ganun pa din bigla nawalan ng power tapos hirap umakyat sa 2000rpm at nanginginig and mausok, pero kapag itinabi ko at naka idle ok naman yung engine maganda naman yung idle.
    ang ginawa ko tinanggal ko yung power connector ng MAF sensor, ok na yung takbo nya at di na nagvibrate at di na mausok, pero ayaw tumaas sa 3k rpm, parang nakalimit lang sya sa 3k rpm. suspek ko yung MAF sensor, umorder na ako ngayon hintay ko na lang dumating. sana yun na nga ang problema, ang hirap kasi kapag intermittent yung problema.
    yes sir bihira lang magamit yung GS, tapos pag gagamitin short trip lang.
    #8069
    Sana may update si bro.mike18.... 😑
    Sent from my Nexus 7 using Tapatalk
    #8070
    sir ok na GS ko, stuck up yung EGR valve, hindi maayos yung pagkagawa nung nagpalinis ako ng egr at intercooler, pati intercooler hose pilipit din, nag assume ako na ok yung EGR kasi bagong linis lang, di ko alam na palpak yung gawa, mabuti magaling yung natawag ko na mechanic, pag start pa lang alam na agad yung problema.
    #8071
    Good to know bro that your troubles are behind you...
    May 2013
    #8072
    hi all, can anyone enlighten me on what model year stability control was first installed on the gls gold variant?
    May 2008
    #8073
    Is there a good Hyundai parts store in the Cubao and Marikina area?
    #8074
    Quote Originally Posted by goldrat View Post
    Nasa bandang Araneta-E. Rodriguez Ave ang mga Korean auto supplies.
    #8075
    Any one here who has installed an oil catch can in their unit? Is it worth it?
    After 70KKm, I am seeing traces of oil in my intake.
    No problem (yet) in the vehicle's performance but I am considering this option
    #8076
    Nagpa EGR cleaning kana?
    Nagpalagay ako dati ng procomp brand, nasa 2.5k noon.
    Wala akong napansing benefit, na extra OC pa parati ko sinisilip kung puno na ng oil yung can.
    After 5 years hindi umabot sa 1/4 yung oil.
    Yung second GS ko hindi kona nilagyan ng oil catch can.
    #8077
    Thanks for the reply bro.
    I had my EGR blocked when I bought the unit in 2009.
    I noticed a few days ago that the intake (after the air filter) has traces of oil
2008 Hyundai Starex (Gen. 4)
