Hataw if given a chance na maluwag talaga. Pero nung bagong kuha ko to pagka skyway ko hinataw ko ng 160 agad 🤣
Good old days hehehe
Planning to have the intake cleaned, may oil residues na kasi. Baka palitin na din intake manifold gasket. Pati suspension bushing ppa check ko na din.
BTT: may nakapag palit na ba ng atf dito via dialysis? Ilang litres aabutin?
Planning sana ipababa yung transmission pan para malinis filter.
Had drain and refill nung 40k kms. Sent from my SM-J730G using Tapatalk
When my unit had low power, had my ERG blanked and CAT removed para hindi na maulit ang low power. Not sure how they removed the inside of the CAT converter since iniwan ko lang sa tayer ng kaibigan ko.
Had ATF dialysis before sa banawe and kinaya ng 12liters of castrol multivehicle atf
Depends on how clean you want it. It took 15 liters with mine before. No need to open the tranny pan. Filter is not a filter, it's a screen wire mesh and since it's a sealed tranny i would not worry about it unless you have metal in the oil (which of course means you have much bigger problems that the filter/strainer.)
(at the risk of being told off "in your dreams" again) Even if you clean the residue and even if the gasket is still ok, and your turbo's oil seal is still ok, there will still be a little oil in the turbo plenum. The oil mist from the crankcase condenses into that little puddle of oil in the plenum. The paste forming from the oily mist from the crankcase + soot from EGR is what can clog up the intake manifold. The oil mist also condenses in the intercooler. That's why people either block the EGR and/or install a catch can.
Currently usinf Zic X7 oil.
Okay kaya Delo MGX 400 para sa Grand Starex?
Also, ano ba nasusunod sa atin? May nagbigay sa akin ng Shell Hx7 API SN/CF pero ACEA A3/B4 na pasok naman sa requirement ng GS
You can buy Hyundai Xteer Oils kay CIKA sa Banawe.
Kumusta naman ang quality ng 10 year old starex? Matibay pa rin ba
Matibay naman. I can still see them roaming around the metro. (Starex with Z plates)
Ano Generation na ba ang Starex TCI 10 seaters 2017 ko na purchased. Salamat
