Page 22 of 25 FirstFirst ... 121819202122232425 LastLast
Results 421 to 440 of 498
    Feb 2019
    #421
    So i had my oil change yesterday and i forgot to tell my mechanic to use only 3.6L he poured in the whole 4L and the dipstick is a little above the max level.
    Mar 2018
    #422
    Ooops
    #423
    can you suck it out via the oil dipstick tube?
    one can make a simple oil suck-er-outer...
    #424
    Oks lang yan. I guess 4/10 of a liter is not much.
    Feb 2019
    #425
    Okay sir. I guess its better to be over the max limit compared to lower than minimum.
    #426
    Overfills? No problem...Another Fumoto advantage.
    Feb 2019
    #427
    So if you are doing oil change using fumoto you just flip the valve and down goes the oil there is no need to remove the whole plug.
    #428
    So if you are doing oil change using fumoto you just flip the valve and down goes the oil this no need to remove the whole plug.
    Exactly, sir. Convenient/clean draining. No more fears of leaks, plug over/under tightening/stripping/seizing. Though not really necessary, Fumoto offers the optional lock clips(black & red)....for added mind peace.
    Feb 2019
    #429
    I check online and mostly are overseas seller is this the F108N model and compatible with all vehicles just one size?
    #430
    Extract your engine's Fumoto model number/s here:
    Search Results | Fumoto(R) Engine Oil Drain Valves
    Mine(F106 w/ LC10 Lock clip) were from Amazon. If your plug is M14x1.5thread pitch, then F106 applies. The F108 is for M16x1.5 plug size/pitch.
    F-16 | Fumoto(R) Engine Oil Drain Valves
    Feb 2019
    #431
    Okay thanks sir. Will replaced for my next oil change.
    #432
    Anytime, dee sir![emoji106]
    Feb 2019
    #433
    Saw this at fb page.... mixing prestone with honda coolant? seems not good to me.
    #434
    Blue ang coolant ng Brio.
    Prestone is Green.
    Feb 2019
    #435
    Prestone is Green.
    Yes but not advisable right to mix coolant with different color? I remember someone posted here that he uses the Mitsubishi coolant also blue which should be compatible with Honda.
    #436
    Second Gen. Honda Jazz/Fit
    Jun 2011
    #437
    Feb 2019
    #438
    Quote Originally Posted by bxr monkey View Post
    Okay actually im planning to buy mitsubishi coolant for top up should the reserve go below minimum level but right now still at max level long way to go.
    Feb 2019
    #439
    For mini sedan or sedan in general is there a max limit in terms of weight per pax let say it seats 5 adults and 5 adults weigh 90kg each so a total weight of 450kg.
    #440
    Sa City nga dati, nag aalanganin ako dala ng 5 people unless short distance. Medyo masikip na for 3 people sa rear seats.
2019 Honda Brio
