Page 12 of 25 FirstFirst ... 2891011121314151622 ... LastLast
Results 221 to 240 of 498
    #221
    For washer fluid is it okay to use dishwashing liquid + distilled water mix? will it not damage the washer pump, nozzle or much better to buy the washer fluid in blade store the blue one.
    it is generally ok to use a dilute solution.
    the soap helps avoid outside mist.
    personally, i use nawasa water.
    after two decades, hindi pa naman nag-bara.
    #222
    kung nag wax ka or protection yun auto, wag mo lagyan ng kahit anong sabon. matatanggal lang wax mo
    Jan 2016
    #223
    Were you able to get the old stock?
    I checked today, gen 1 & 2 is using same fuel strainer
    PN# 17048-TG1-P00
    Strainer assy filter is built-in. P3,458
    Attachment 36656
    Attachment 36657
    The fuel strainer of the Civic FB looks the same but costs about 6k to replace in casa, which is I haven't replaced mine yet though it is going 7 years this mid June and 82k kms now
    Feb 2019
    #224
    The 6k is for the material cost or material and labor cost combined? I think you should have it replaced before it clocks in 100k
    Jan 2016
    #225
    Material lang, I tried to buy one kasi dati, I can't find my manual now but IIRC, 40k or 2 years ang replacement dapat nito
    #226
    Should be similar
    Jun 2011
    #227
    Nag roll back ba sila? Suki ako ng Mineral nila na 5w30 SN, almost 1k bili ko sa casa
    780+ pala. Hindi ko alam kung nag roll back. Iyan ang charge sa akin last Dec 2019 24 month PMS ng Honda Quezon Ave, VAT inclusive.
    #228
    i kinda trust the banawe folks, on what non-OEM part works and what doesn't.
    but then, i'm a toyota and not a honda.
    #229
    Distilled water is ideal, chemicals tend to build mineral deposits/calcify blocking the hozse and noozle. Just like what dr have said, tap water should be fine if you don't intend to keep the vehicle for 20+yrs. Just clean reservoir from time-to-time,"sundot" the noozles, keep windshield clean and maintain the wiper blades..
    Feb 2019
    #230
    Okay thanks so i'll just use distilled water and im also wary of using dishwashing liquid and the chemicals in windshield washer. It is just that spraying distilled water alone would not give the lubricity needed to clean the windshield.
    Jan 2008
    #231
    Just buy a windshield washer fluid.. less than 200 pesos per 2 liter jug.. will last you more than a year.. helps your wiper last long too..
    Feb 2019
    #232
    I check on the air filter and its fixed inside the black casing I thought it is removable.... is this washable same with cabin filter? will just wash it once or twice before replacing it.
    #233
    ^OE air filters are disposable bro, replace in 1yr or 20k kms.
    If for inspection/temporary cleaning, shake/vacuum the outside part to loosen/suck the dirt. Vacuuming from the inside forces more dirt thus clogging the element. Filter element deteriorates when washed, i'd only do this temporarily if replacement is not readily available. Make sure its completely dry else it could choke the engine.
    By the looks of your filter/discoloration from the inside, its stuffed and needs replacement.
    Feb 2019
    #234
    Okay thanks bro. I'll just replaced it with Sakura that you posted before but will they noticed that I replaced it with aftermarket because I will be doing pms in casa. How about the cabin filter? Is it washable? because in my other toyota ride I just wash it once or twice if it is not that dirty yet.
    #235
    Use only orig filters if still under warranty, that will be the basis for warranty claims. You could show your receipt if you're bringing your own supplies and iff service allows it. Dirty filter could result to erratic idling, poor FC, fouled air-flow sensors, accelerated wear of oil. Same goes to cabin filters as the dirt build-up on evaporator often causes premature corrosion,AC leak, damaged blower motor.
    After warrantey, you could do much TLC by replacing twice or more if you want using replacement filters which cost3x or less of the orig. Same goes with cabin filter. Theoretically cabin filters esp those synthetic media can be washed depending on how clogged it is. those with activated carbon are not washable as it loose the carbon if washed.
    How many yrs to wait pa before warranty expires?
    Feb 2019
    #236
    Okay bro noted on this. Next year the vehicle will be 3yrs so I'll just do pms at casa this june and probably another one on january 2021 and that's it.... after that I can do it on my own with non-casa I think most of us here who are knowledgeable with maintenance do it outside casa after 3yrs or some do remain with casa?
    #237
    Some would stick to casa esp those without know-how, no time, dispose car every 3-5yrs.
    Some would DIY for hobby and to save money
    On my personal rides, i'm more comfortable knowing the vehicle quirks, maintenance, temperament predictability as i do lots of long driving, my safety depends on it. For the hard, time-consuming, and dirty jobs i just delegate them to shops or local help.
    Feb 2019
    #238
    Can you help me identify the two circles? is it fuse box and ecu? not written in the manual..... also I noticed that the oil filter for this engine is located at the bottom so you need to lift the vehicle to have it replaced.
    #239
    We have different lay-out. Mine is just air pre-cleaner and ECU centronics connector is upside. Maybe you could open that yellow box to further investigate. My fuse/relay box is inside almost impossible to check without removing the lower steering-cover.
    Feb 2019
    #240
    My fuse box is also located inside the lower steering cover. So if one fuse box only this might be other component inside the hood. All other parts I can identify just these two circles.
2019 Honda Brio
