Results 14,811 to 14,820 of 14858
June 1st, 2020 06:35 PM #14811
June 1st, 2020 08:05 PM #14812
- 52,514
June 1st, 2020 08:25 PM #14813
- Nov 2009
- 3,474
June 1st, 2020 08:27 PM #14814Pede dine in? Yung dala ka sarili fluids with purchase receipts from other casa or from authorized distributors?
Sabihin mo sa SA sa ibang casa ka nalang mapagawa yung allowed ang take out.
June 1st, 2020 09:00 PM #14815
Not sure sir, walang nakalagay sa owner's manual regarding that. Eto ang nakalagay sa manual regarding coolant
Always use genuine Honda All Season Antifreeze/Coolant Type 2. This coolant is pre-mixed with 50 percent antifreeze and 50 percent water. Never add straight antifreeze or plain water.
The cooling system contains many aluminium components that can corrode if an improper antifreeze is used. Some antifreeze, even though labelled as safe for aluminium parts, may not provide adequate protection.
If the reserve tank is completely empty, you should also check the coolant level in the radiator.
Although Type 2 ang indicated sa manual, Type 1 ang nagamit ko before nung nagpalit ako ng coolant dahil sabi nung SA yon lang ang available nila. May nakita din akong thread dito regarding na hindi nga makabili ng type 2 coolant sa mga honda dealership. Honda Type 2 Coolant
June 1st, 2020 10:16 PM #14816
^anti-freeze is for winter environment..since winter doesn't happen in the philippines..it doesn't matter
June 1st, 2020 10:56 PM #14817
- Jul 2009
- 2,618
June 16th, 2020 02:17 PM #14818
- Jul 2009
- 2,618
June 16th, 2020 02:25 PM #14819thanks pala sa condensed chart. this greatly helped me understand yun slightly complicated modern coolant info. ang dami pala.
p.s. a couple of years back i tried flushing a supposedly lifetime OAT pressurized cooling system. walang problem sa drain. yung refilling ang MAJOR pain in the behind maski mayroon pressure release valve for some reason maybe my own ignorance di ko ma "burp".
i will never forget that 10,000pesos coolant change. i still cringe now as i think about it. 7000 for towing and another 3000 sa casa for them to use their vacuum machine and properly refillLast edited by babkalakal; June 16th, 2020 at 02:34 PM.
June 16th, 2020 03:09 PM #14820
I suggest bili ka nalang sa honda. 368 per liter yung Green coolant nila. Ginamit ko na rin yung sa Shell reco cool. Nag leak after 6 months of use kahit pinalitan ko na yung hose clamp. Kaya binalik ko nalang sa Honda green coolant.
sinabi moh! i hardly see my children now. when they were young, schedules were more predictable.
Traffic!
