Page 13 of 25 FirstFirst ... 39101112131415161723 ... LastLast
Results 241 to 260 of 498
    #241
    I think that box encircled yellow is part of the pre-cleaner chamber while purple circle is the ECU with connector on the side.
    Feb 2019
    #242
    I see so inside the yellow circle there is no filter or nothing in there that requires periodic maintenance replacement? Ok so its ECU.... how about the fuel injector is it located at the rear seat? I didn't noticed it earlier. If I will be going for engine wash since its a bit dirty, all of the components can be sprayed with water? is there components that I need to cover with plastic.
    #243
    apologies, but
    doesn't the owner's manual have diagrams of the engine bay components?
    Feb 2019
    #244
    apologies, but
    Again, the owners manual doesn't specify everything in the engine bay it just state maybe 5 or 6 major components if I remember correctly. It is a thick manual but the first half of it I keep on skipping unlike toyota's manual few pages but discusses more specific.
    #245
    it would appear,
    your honda manual isn't too DIY-friendly...
    #246
    Pre-cleaner is just air baffle to circumvent larger debris like twigs leaves. it also acts as barrier from water ingress if you happen to swim above hub-high flood. Inspection and cleaning may not be required if you don't drive to the extremes.
    Fuel injector is usually adjacent the spark plug(i think you have to remove the plastic engine cover to reveal,have a set of socket wrench to do this) There is this rail pipe of the fuel and return pipe plumbing and electrical connector on top.
    Engine components are water splash resistant IPxx rated including the connectors, but to be sure just cover the important parts like ecu,battery fuse,some connectors, air cleaner inlet. Avoid using pressure washer, instead use a sprinkler or garden hose. For the stubborn oil/grease/dirt, you could spray brake cleaner to dissolve and flush it.
    Nov 2017
    #247
    apologies, but
    The manual is somewhat confusing (well india only gen 2 amaze's is )the engine diagram is on page 250 while the fuse box locations is on page 300
    Jun 2011
    #248
    SOHC L engines natin, ang spark plugs nasa exhast port side, malapit sa firewall side.
    Fuel injectors nasa intake port side, malapit sa radiator side ng engine. Nasa ilalim ng intake manifold ang fuel injectors.
    #249
    Quote Originally Posted by bxr monkey View Post
    The mechanic who serviced our old Honda’s before hated it when we change plugs on our 2009 Jazz. You have to be patient when pulling out the plugs.
    Feb 2019
    #250
    I saw the spark plugs right behind here. But didn't noticed the fuel injector should be near the coolant reserve I'll check again tom.
    Feb 2019
    #251
    For this vehicle the ground clearance is 150mm as stated in their website is this among the lowest ground clearance for vehicle in its category?
    #252
    Not really. 150mm is pretty average for sedan/hatchback. The Civic has a lower ground clearance of 135mm.
    #253
    Smaller cars seem to have higher ground clearance than bigger sedans. Our old 2009 City sits higher and stands taller than our old 2001 Accord. The Accord is lower to the ground and wider.
    The 2016 Jetta also sits as low as the 2016 Civic in terms of ground clearance. Almost as low as the Accord.
    Jun 2011
    #254
    Heto, mukhang ok na video sa injector location:
    Episode 28. 2008 Honda Fit fuel injectors replacement. - YouTube
    Oo nga, tapos iyong windshield at dashboard lagpas sa firewall, kaya na takpan partially ang access.
    Na appreciate ko tuloy engine bay ng new Ertiga.
    Feb 2019
    #255
    Okay thanks sir. Glad to know that it is on average I was thinking of making the tires 1 size bigger to up the ground clearance.
    Feb 2019
    #256
    OT:
    For this type of dirt inside car sidings is it okay to use MC or Wipeout or need to buy upholstery cleaner? this are tough stains to remove.
    #257
    OT:
    for that particular part,
    i recommend you remove it and clean it with ordinary soap, water, and toothbrush.
    more likely, the dumi you see, are minute fragments of previous loads. paint chips, plastic chips, etc.
    Feb 2019
    #258
    I tried using some dishwashing liquid and a bit of soap just rubbing it and it won't remove the dirt. I didn't use toothbrush won't it scratch the sidings? This is the part where we step foot on and easily gets dirt.
    #259
    yespo.
    those are not dirt.
    those are scrapes.
    kung baga sa fender,
    hindi yan dumi.
    bangga 'yan.
    try nyo mc or wipeout.
    read the instructions.
    but try it first at a hidden part, as it might discolor the plastic, even if the instructions say it will not.
    Sep 2016
    #260
    Do honda casa allow you to witness while they are doing pms? I always see and check what the mechanic is doing.
    Honda GH has big glass windows facing the service bay so you can see your car being serviced. They also allow you to watch beside your car if you want. Ewan ko lang ngayon kung pwede pa due to the virus pero malamang hindi na.
    Nung December na last PMS ko, I was there beside the car nung nagpaturo ako paano magpalit ng headlight bulb. Dala ko na yung Orsam NBL at dun ko pinakabit. Pinanood ko lang pano palitan. Mahirap pala sa mataba ang kamay.
2019 Honda Brio
