Page 2 of 15 FirstFirst 12345612 ... LastLast
Results 21 to 40 of 498
    Them tiny yellow cars....[emoji106][emoji4]
    These cars are on a different league. The Brio is way below the pecking order. Hehehe
    They're all tiny, Egan bai....yellow, secure & kept simple.[emoji6]
    it doesn't matter. you make do w/ what you have. you deal w/ the cards you're dealt with.
    Apr 2014
    The cursive lettering at the windshield of the vw is..... meh
    Quote Originally Posted by chronicle View Post
    Haha...nuffsaid, sir?[emoji13]
    Baka “wifesaid”. Hehehe
    Ahhhh...is that the silent majority, bai?...Yellow is just perfect!!![emoji16]
    why didn't you say so, earlier!
    it makes all the difference.
    Apr 2014
    The yellow color should have been totl.
    It was an iconic honda color back in the day.
    Apr 2014
    Sasayad saan?
    May mga mas mabababa pang sedan at ok naman sila generally... Generally.
    Of course, may mga humps na alanganin at parking ramp na matarik na kelangan alalahanin.
    Jan 2019
    Mga boss may na encounter na kayo ganito?
    Creaking noise when releasing brake pedal from full stop - YouTube
    Normal po ba to? Tumutunog po sya ng ganon kapag inaangat ko yung brake galing sa full stop. Kapag naka drive or reverse lang tumutunog. Kapag na park or neutral, wala naman. Bago lang po V CVT yung unit ko. Nag tanong ako sa ibang members ng brio group, accdg to casa normal daw. Hmm
    Salamat po!
    Sent from my SM-G570Y using Tapatalk
    Quote Originally Posted by kasmot95 View Post
    Salamat po!
    Normal????[emoji54]...That can't & shouldn't be.
    Jan 2019
    Kasi inaalala ko baka pag dating ko ng casa. Yun din ang sabihin, NORMAL lang yan [emoji22]. Wala na ata ako laban nun. Pagkalabas pa lang ng unit, narinig ko na. Tsaka mejo marami din nakaka experience. Dapat yata inintay na lang namin mazda 2 kahit mejo pricey [emoji24]
    Jun 2006
    Not normal most definitely. Have driven a lot of cars already in my lifetime. Owned several hondas as well... creaking sounds when releasing brakes are normal, but that noise is not a creaking sound but rather a thumping sound. Demand for that to be fixed.
    Delikado sayo at sa ibang tao kung ang sasakyan mo ay may problema sa brakes. Demand that from Honda... that is unacceptable.
    Aug 2017
    Salamat po!
    Normal. Same with our brv. Happens if it's humid, raining or car is newly washed, in short pag basa or may kalawang na namuo sa rotors.
    Quote Originally Posted by ieddam View Post
    Odd sound for rotor rust, though. Try having the calipers & pins lubed w/ the proper brake grease like this Permatex....
    Lazada
    Aug 2017
    Lazada
    If there there is a problem with the piston or pins it's only logical na dapat anytime he will hear the sound regardless if it's from a full stop, car in neutral, or braking from high speed. But as he said, he only hears it when coming from a full stop. Plus the car is brand new, you would think it would have passed quality control and have been properly lubed and greased.
    Rust-induced noises usually occur upon initial use & disappear once all the rotor surface rust is friction-cleared. Unless I misread the post & the video, that noise upon every pedal pounce can't be accepted normal regardless of the car's age nor presumed factory PDI. Just helping the hunt, sir.
    Salamat po!
    Jan 2019
    Good to know. Thank you sir. Umuulan nga nung nailabas ko yung unit. Try ko i observe pa.
    Jan 2020
    Salamat po!
    Same sakin sir, may ganyang sound pag naka engage yung Drive tapos inapakan yung brakes from full stop. Kala ko sa akin lang.
    Will have it checked sa casa sa 1st PMS.
    RS CVT.
2019 Honda Brio
