This assembly (filter-pump-float level sensor) should be similar. The filter is the ones on the bottom-most part like a wire mesh.
I'd be careful leaving a loose electrical connector on that(best use silicon grease for insulation) imagine spark inside flammable vapour, your car becomes a naphthalene bomb.
For diesels its more complicated since fuel alone is dirty and thick oil in nature (which is prone to bacterial bloom, coagulation, water contamination from blending ethanol and precipitation of tank). The pump, filter, float are usually separate. Fuel system must be cleaned by filtering and coalescing the water(water separation) so there are even sometimes separate filters for these. Some diesels does not even have an electric pump the fuel injector does the sucking.
Fore-axle is now the common adapted tank location. More for safety, away from crumple zones. Access from the tank floor? This would require emptying your tank prior to filter/pump service. More work.
Oh, a tip, bring your fuel level down to a fourth left prior to doing it. Less mess.[emoji4]
Yep front engine compartment is already crumpled. Thank you for the tip.... But still long way to go before replacing the fuel filter. Im just surprise on the location and process of replacing it as a first timer owning a sedan. I assume labor cost for this one will be much higher? In diesel replacing fuel filter element they just charge 300 pesos.
I check the driver seat side and the recommended tire pressure for front is 33psi and at the rear is 30psi. If the car is loaded with 5 passenger (including driver) is it okay to make the rear tire pressure also at 33 or just stay at 30psi.
I have watch the video. The fuel filter is the cylindrical aluminum object that he pulled out and spray on it? then later on put grease..... so he just cleaned the fuel filter and put it back on again. I can also see a lot of sensors in the assembly.
^ I have to double check the fuel parts as its suggesting on the manual that there's an "in-line" filter separate to the pump-float-fprv-strainer assy.
