Finally got to spend good time with the Ranger XLT MT. It's more crude and rugged than I expected, but I still liked it.
With the Wildtrak now out, the XLT does look a bit plain in comparison. I'm not exactly sure how I'd approach the Ranger's exterior, but probably if I do get one, it'd be in white, and I'd have the grille painted matte black, as well as the lower part of the bumper (or maybe the middle like the Wildtrak, not sure). Tires look a bit skinny, and would probably look better if it were a bit wider with 18" rims (not a fan of oversized 20" rims that everyone else has). I was pretty shocked that its bed was actually shorter than our 1991 L200's. My bike certainly wouldn't fit unless I take the front wheel out, or perhaps I load it diagonally.
One thing I noticed with the interior was that it was mostly plastic, with very little fabric on the doors. It's actually a good thing if you plan to subject the truck to heavy use, since it's much easier to clean. Bluetooth worked fine and I had no problem syncing my phone and iPod, just like with the Fiesta. However, what sucks is that they didn't improve the voice recognition from the Fiesta either - dialing numbers still remains to be an irritating experience and you're better off just using the d-pad or keypad to find the contact you're looking for. Overall, the interior looks more modern than that of the Strada or Hilux, despite being rugged in nature. Rear legroom was also better than the Strada's by a few inches, though I think the latter still has more reclined seats. The under-seat compartment was also a nifty touch, especially since you don't really get a secure trunk with a pickup.
Taking the truck out for a drive, the first thing I noticed was the rather, er, agricultural driving position. I'm a small guy and finding the right driving position was a bit hard with the large dashboard and low seats. Looking out through the windshield of this tall and wide truck would take some getting used to. Certainly, the Strada's driving position was more intuitive and car-like. The clutch also takes some getting used to - somewhere halfway through its pedal travel, you'd feel some sort of resistance, as if there was a hump. At first I thought that was the clutch's friction point, but it wasn't (friction point was deeper through the pedal range). It made smooth shifts hard, since it's harder to modulate the clutch through that "hump". One more thing I noticed was that the gears were placed really close to each other. Not in terms of the gear ratios, but to how they're slotted on the shifter. It's easy to mistake 2nd gear for 4th, so this too takes some getting used to. Overall, in terms of driving ease, the Ranger isn't an intuitive car. Heck, I found it much easier to drive our old L200, and that too is a truck - a more ancient one at that.
On the open road, I expected the Ranger to be underpowered like what everyone's been saying. That wasn't the case. The engine revved happily so it was easy to find yourself in the powerband as long you find the right gear for it. Below 2000 rpm, there's adequate power to go strutting about at normal speeds, but if you wanna stretch the truck's legs a bit, you'd have to shift up to maximize the engine. That said, it has none of the push-you-in-your-seat power of the Strada, even at the redline. 28 hp on paper does translate to a noticeable difference on the road, at least in this case.
I wasn't able to take the truck out hill-climbing, but I don't think it should be a problem. Again, our 70-hp pickup has no problem (as long as you're in the right gear) so the Ranger should find it easy especially with double the horsepower. One thing that puts the Ranger ahead of older pickups is how quiet it is inside the cabin. Below 3000 rpm, there's barely any audible noise from the engine. Interestingly, when pushed to the redline, the sound was quite pleasant, certainly a big improvement from the stressed clatter of older diesels.
I tried throwing the Ranger into a corner at speed, and surprisingly, it turned without much struggle, with some tire screeching on the way out. On normal road humps though, the suspension is too stiff for my rear passengers, and even in the driver's seat I felt the stiffness of the rear suspension as it shook the cabin. As others have pointed out previously, the Strada's still the better choice when it comes to comfort.
At the end of the drive, the Ranger isn't the runaway winner I expected it to be. There are some things that I have to get used to, but looking at the bigger picture, this is still the best mid-range pick-up out there. Its eye-catching looks, decent handling and competitive feature set are enough to offset its crude quirks, so-so performance and stiff ride. At 1.069M, it's actually affordable too.
As a side trip, I also tried the 3.2 Wildtrak. I expected it to be a powerful beast that's tough to handle. It has 200 horsepower after all. However, the Sportage CRDi which I drove right after felt faster and more agile despite a 23hp deficit. The Ranger does feel much torquier than a Strada, though I think the latter can match it on the highway. It would've been nice if there was a 3.2 MT Ranger, since the AT failed to have the same pep and verve that I felt from the 2.2 XLT MT.
