Page 6 of 26 FirstFirst ... 234567891016 ... LastLast
Results 101 to 120 of 511
    #101
    Anyone ever get a boost controller and start running more boost?
    unfortunately, I barely hear any tsikooter using a boost controller. too bad because I'd really like to know how much, where locally...
    so far, people here only do the washer mod. which I also use.
    Sep 2005
    #102
    dvldoc, Just wanna ask if your alcohol kit does have a 1 year warranty on it? All parts!!?? From pump, tubing, adjustable pressure switch, valves..etc..etc.?
    My alcohol kit didn't even last for one month after I had it installed. It just went dead. I recall you last said that it's a 1 year warranty on all the devilsown parts.
    Just looking for the right opportunity to send my vehicle back to Speedlab since they're conducting road and irrigation repairs that are blocking most of the entrance road of the store.
    Dec 2007
    #103
    Yes they have a 1 year warranty, high heat is only thing that can really kill that pressure switch. We advise not to mount it at the intake pipe but to the side of the engine bay.
    Aug 2009
    #104
    Quote Originally Posted by rion View Post
    I have replaced my boost guage to AEM Boost Controller on my 2005 A/T 4x4 Everest last June 2009.
    [SIZE=3]http://www.aempower.com/ViewCategory.aspx?CategoryID=68[/SIZE]
    [SIZE=3]Here's how it looks on my EVE:[/SIZE]
    [SIZE=3]http://i30.photobucket.com/albums/c311/rol_z9/IMGP1053-Copy.jpg[/SIZE]
    [SIZE=3]Top Guage is the AEM Tru Boost Controller. I purchase it early this year online at www.summitracing.com and my landed cost in Riyadh, USD420 shipped via UPS.[/SIZE]
    [SIZE=3]Below is my EGT Gauge from [/SIZE]
    [SIZE=3]http://prosportgauges.com/Prosport-Blue/White-exhaust-gas-temperature-gauge.aspx[/SIZE]
    Jun 2008
    #105
    para saan yang bosst gauge di ba madali masira yang alcohol injection kze sabi sa ibang thread 8 months lang nya nagamit ung alcohol injection ung isa naman 1 month lang
    May 2007
    #106
    SPEEDLAB installed the pressure switch in the INTAKE PIPE before the manifold
    Do I need to relocate it ?
    My ride is a 2010 3.2L strada sport.
    Jun 2004
    #107
    [SIZE=2][SIZE=4]BUMP![/SIZE]
    A very interesting thread!
    Kumusta naman po ang mga nag-setup nito, sa ngayon?
    Meron na po bang dealership/retailer dito sa Pilipinas?
    So, pwede pala sa N/A engines...sino po ang nakapaglagay sa N/A gasoline engines nila? At kumusta naman po ang performance at pwede po ba kayong magbigay ng feedback?
    Maraming salamat po!
    [/SIZE]
    #108
    Mine ay sa turbo charge na FM. Performance wise ay really ok, feel mo yung kick ng boost.
    Jan 2011
    #109
    could you please share to us how much and where can we get the kit? im interested, XUV A/T turbo. TIA.
    Aug 2006
    #110
    Quote Originally Posted by shelu View Post
    Sir, you can checkout Speedlab.
    SPEEDLAB | The Science of Speed
    Jan 2011
    #111
    Quote Originally Posted by denier13 View Post
    thanks sir. got it.
    #112
    berrima diesel is a distributor too
    #113
    I have a devil's own water injection installed on my MPV since 04/2008.
    Ngayon, mahina na pressure nung pump. hindi na maka produce ng water mist yung nozzle.
    I stopped using it for more than a month now. Try ko baklasin yung pump. and will post pics for reference dun sa mga other owners.
    #114
    Quote Originally Posted by rmpmla View Post
    Any idea how many highway kms you've done since the install sir?
    #115
    I averaged about 20,000Km a year. so for 3 years, that would be 60,000Km.
    But since the water injection is not 100% activated during travel, I would guesstimate to be at 30,000Km where water injection is used.
    Dec 2007
    #116
    Give me a pm, Your seal is probably bad on your pump, the hard water there can be hard on them. You can run 5% hydrochloric acid through the pump to remove deposits (basically over the counter hardwater stain remover). And I can show you how to reseal the Pump with RTV silicon adhesive.
    #117
    *dvldoc, thanks.
    I just dismantled the shurflo pump and found the the pump parts to be okay. what i have noticed is the worn out bushing/coupling (outer part) insert on the motor shaft. this bushing/coupling is mated to the inside diameter of the bearing which converts the motor rotation into pulsating motion of the diapragm.
    What I just need is to make a tight fit between the bushing/coupling outer part to the bearing's inside diameter.
    will post pics later
    May 2010
    #118
    I really wanna install this on my rig, kaso saka na muna. hehehe.
    Dec 2007
    #119
    *dvldoc, thanks.
    Any shop that can repair a starter motor can fix that for you. It's basically the same thing as far as the motor goes.
    #120
    problem on pump solved! just put a shim on the coupling for a tight fit and now being used, again.
Water/Alcohol injection Turbo Diesel use
