Page 1 of 9 12345 ... LastLast
Results 1 to 10 of 89
    Feb 2017
    Im a Grab Driver and after I drop the passenger off I am turning off the engine to save fuel consumption, after 5-10 minutes I will start it again. Is this ok? Am I shortening any parts of my car? Please help, I will appreciate it very much.
    Nov 2017
    Quote Originally Posted by danegoesonline View Post
    No problem and you also help save our environment [emoji106]
    Feb 2014
    ok lang yan. some newer cars even have auto start stop systems. automatically kills engine when idling
    starter is an electric motor and is usually very reliable
    what's bad are repeated short trips. like starting cold then driving 1km. then rest 1hr. starting cold again. rinse repeat
    Feb 2017
    Pero ano po yung na wear na parts pag nag iistart ng engine? Spark plug?
    i used to that with my diesel, during long stoplights.
    hayun... battery died on the 13th month, 1 month after warranty expired.
    Jan 2016
    Doc, in my experience with Motolite Gold , patama talaga ang life nya sa warranty na 21 months, minsan lang ako naka tyempo ng more than 2 years and malas na na trade in ko pa for a new one due to mis diagnosis of faulty alarm module.
    Sep 2016
    IMO sir battery madali masira sa ganyan senaryo lalo na maiksi lang takbo kung sakali:-)
    Sep 2006
    Starter and battery.
    1. Battery
    2. Starter motor carbon brush, solenoid contacts and starter pinion gear. Yung carbon brush madali lang palitan. Most starter solenoids are now sealed type so palit yan buo. Also the pinion pag nabungi or worn out palit na agad at baka kasi madamay ang flywheel gear.
    Feb 2017
    Paps alam mo ba pagkabasa na pagkabasa ko ng reply mo ayaw na magstart ng tsikot ko, mag pajumpstart pako sa motolite.
Is it bad to turn the engine on and off frequently
