Results 1 to 13 of 13
    Feb 2017
    Nag spray ako ng water sa rib side ng belt hindi huminto ang squeak. It is very hard to determine saang bearing nang gagaling ung noise, is there anyway na malaman ko which one ung squeaking? And then pano ko malaman ung bearing na bibilin ko?
    Quote Originally Posted by danegoesonline View Post
    If you are done checking the drive belts for cracks, you may remove one-by-one the drive belts to isolate the accessories (PS pump, AC compressor, alternator, WPump). Once you identified the bearing, check the part number printed on the cover then ask the bearing store for replacement. If water pump is the culprit, replace the assembly as the bearing is pressed on watertight seal.
    my usual bet is the idler pulley bearing.
    Dec 2017
    I want that stethoscope! What do you call that thing?
    Mechanic's stethoschope. Nagkalat sa Lazada less than P500
    Dec 2017
    So, it is really called as a stethoscope. Thank you, I might give this as a gift to my brother who is maintaining an older car.
    I remember using a copper tube whose end is pointed and the other end with a 1 cm diameter sphere. I'm​ not sure if it's called "listening rod".
    I think OP should just bring his car to a mechanic to avoid making a mistake, if he can't find the simple squeaking sound I don't think he'll be able to do thr steps posted of removing belts and everything.
    Jan 2008
    Pwede din sa crank shaft pulley galing yung squeak.. usually pag bearing ang sira may ugong yan na tunog na parang riles ng tren
    Feb 2017
    Pwede b stethoscope ng doctor un lng meron aq
    Sent from my SM-G532G using Tapatalk
    Jan 2018
    Pwede rin pero baka mabingi ka
    Sep 2018
    Also try checking for rust build upon the grooves of bearings as this also causes squeeks. Water method isn't always effective because you are wetting the belt and not the bearing, which is a test done for belt tension not bearing wear.
    Check muna belt kung maluwag. If not tsaka punta kung bearing.
    Feb 2017
    Mga tsikoteer, pag yung squeak nag appear lang pag pkatapos patayin ung aircon at fan ano ibig sbhn? Pag initial start, walang squeak.
Bearing squeaky noise
