Page 245 of 390 FirstFirst ... 145195235241242243244245246247248249255295345 ... LastLast
Results 2,441 to 2,450 of 3899
    Mar 2012
    #2441
    You might want to check with berrimma diessel for some of my fine filters soon, sorry no 4m40 filters in stock yet.
    The Caterpillar 307B excavator uses the 4M40 engine. The CAT dealer or heavy equipment parts stores might have the oil filter for this engine.
    #2442
    Quote Originally Posted by Rocko24 View Post
    It's the 4m40E1 which I think has a different thread.
    WIX FILTER 51798 CASE OF 6 Caterpillar Mitsubishi Isuzu | eBay
    "PARTS DETAIL
    Principal Application: Caterpillar, Detroit Diesel Engines, Hitachi Excavators, Isuzu H.D. Trucks, Mitsubishi Trucks
    Style: Spin-On Lube Filter
    Service: Lube
    Type: Full Flow
    Media: Paper
    Height: 5.968
    Outer Diameter Top: 4.282
    Outer Diameter Bottom: Closed
    Thread Size: 1 1/8-16
    By-Pass Valve Setting-PSI: None
    Beta Ratio: 2/20=24/45
    Burst Pressure-PSI: 420
    Max Flow Rate: 18-20 GPM
    Nominal Micron Rating: 32
    WIX 51675/51067 yung puwede sa 4M40 eh.
    PARTS DETAIL: Wix 51675
    Principal Application: Mitsubishi Trucks
    Service: Lube
    Type: Full Flow/By-Pass
    Media: Paper
    Height: 5.981
    Thread Size: 26X1.5 MM
    By-Pass Valve Setting-PSI: 13-16
    Nominal Micron Rating: 6
    Ganda nga ng micron rating nitong Wix 51675 eh, biruin mo, 6. So 50% efficient at 6 microns. Parang original LF3564.
    #2443
    i think there are other resellers of baldwin in caloocan. just this morning, i saw a guy in a motorcycle along c-3 road. and there is a baldwin logo printed on his shirt. wasnt able to get the company name on the front of his shirt though. he's wearing a blue shirt.
    #2444
    Hi doc just wanna ask if baldwin b1446 is the correct filter for my isuzu 4JA1 n/a engine? i'm going baldwin all the way... hehehe
    Dec 2007
    #2445
    Yes that one works as well as the fleetguard lf3528 which i have lilike 70 of them at the house here.
    #2446
    If I cant source baldwins b1446 in caloocan, i 'll drop by berima. thats where you had them at stock right? Berima is too far from me...
    Dec 2007
    #2447
    i LBC
    Jan 2008
    #2448
    *doc,
    amen!
    #2449
    i LBC
    That's great Doc, I'll send you a PM on my next oil change .. If I use LF3528 on delo Gold, would it be good for 7000K for a 1 year use? can't seem to find delo 400 on auto supplies... delo gold has isosyn ...
    Jan 2012
    #2450
    Okay ba vic filters?
Remote bypass oil filtration
