Page 95 of 195 FirstFirst ... 4585919293949596979899105145 ... LastLast
Results 1,881 to 1,900 of 3899
    Dec 2009
    #1881
    dvldoc, could the use of wrong oil cause a turbo charger to "sweat" oil? my 4m40 has a small oil leak at the compressor outlet of the turbo charger. im not sure if the leak occurred during the rebuild of my motor (failure to clean the leak from the repair) or after.
    current oil used is Shell Rimula R1 SAE40 API-CD. ran 3,000km.
    Bro, the oil that you are seeing on the turbocharger outlet side is normal... that is if the PCV recirculation system is till present...
    the PCV system vents the blowby gas towards the intake side of the turbo compressor, the vapors will condense and form a liquid oil on the discharge side of the turbo.. thats normal....
    if you want that oil to lessen, you have to put catch can.. or if you want it to completely disappear you have to disconnect the PCV hose and let it vent the vapors into the atmosphere...
    #1882
    Quote Originally Posted by miko101130 View Post
    miko, i thought that there will be a thin coat of oil. i didnt expect it to leak. although not that much naman. probably 2 spoonful worth lang. i have an oil catch can, but havent installed it yet. looking for a machine shop that can do an 18mm nipple lang.
    May 2005
    #1883
    Just wondering what is the logic (aside from money) behind casa dealers service center in advising (or requiring) to replace the OEM filter every 5K (even those on fully synthetic oil)?
    Oct 2011
    #1884
    I think they should be lectured by dvldoc.
    May 2009
    #1885
    IMHO, it's only for the money...talaga bang pinapalitan yung oil or filter during the PMS? pwedeng both, either or none. unless kung nasa tabi ka ng mga mechanics nila.
    Dec 2007
    #1886
    They go by the factory recommendation for oil changes but almost no manufacture recommends 3000kl most also go by miles for the recommendation.
    3000klm is only 1850 miles, That's crazy to change your oil that often. 5000klm is closer to the old standard of 3000 miles.
    Most newer cars have a oil life monitor so they have done away with the recommended oil change intervals.
    Here's some examples of older manufacture oil change intervals, most of these now are at 7500 miles to 10000 miles or just recommend the you go by the oil life monitor.
    Dec 2009
    #1887
    casa recommends( actually blackmails you) into adhering to 5k OCI... even with fully synthetics being used on your engine, kasi nga its business... the more they service the vehicle the better it is for their income statements...
    fleetguards, baldwin, wix,purolator... champion labs who make crazy good filters, how come car manufacturers don't use those products? how come manufacturers wont ask champion labs to make good filters for them?
    kasi nga pag maganda nilagay nila at tatagal ang interval, liliit kita nila....
    the casa are selling their service parts for a price that's not even close to being realistic....
    imagine this, 4 years ago the price of brake pads (front only) for the everest at ford Q.AVe is around 2000 pesos, last week i inquired it was now priced at 9000 pesos!!!! ( mas mahal pa sa EBC at tanabe racing pads ampucha!!!)
    May 2009
    #1888
    Quick question here: Is the Fleetguard FF5160 (cross for MB 220900) inside-out flow or standard flow? Thanks
    Dec 2007
    #1889
    Yes the FF5160 is inside outflow, The Baldwin is a much better filter, that Fleetguard is only 40 microns * 98.7% and 20 microns at 50%. The Baldwin is 15 microns at 98.7% and 5 microns * 5%. OEM is 10 microns * 50%.
    I would go with the BF7534.
    Sep 2011
    #1890
    Just want to ask tsikoteers what you will choose between a WIX and a Fleetguard replacement for a BD28. Volmax said that they will have the BD28 by the end of April and now they are telling me they will have it by June, don't like to buy from them anymore. My concern for the FG is that the ones they are selling here seems to be inferior to the ones being sold in the US as seen in the previous posts. Wix on the other hand I think does not filter as well as FG and Baldwin. Just want to know your opinions.
    Dec 2007
    #1891
    Quote Originally Posted by butchyboy View Post
    Well when shipping from overseas there can always be delays.
    But as far as the WIX goes, on this particular filter, yes they have a cross match that would work but the nominal rating is 30 microns which is not very good. The Baldwin is 12 microns. Normally WIX filters are very good but not for this particular application because.
    But this does not put them out of the picture, If you can find the 51675 it's 19 microns nominal, It is slightly larger than the BD28 equivilant. I know some 4M40's and 4D56's have that Aircon hose that can block a larger filter so you will have to check if you have clearance.
    51675
    Height: 5.981
    Outer Diameter Top: 4.282
    BD28
    O.D.: 3 11/16 (93.7)
    Length: 5 3/8 (136.5)
    If you do have the extra space you can also go with the BD7028.
    Oct 2004
    #1892
    Hmm.. So the OEM fuel fiter is better than the Fleetguard FF5160 I'm using right now?
    #1893
    Goodluck on wix, went to superior motors last january and ordered filters for 4d56, they said they are going to call me when my order arrives, well, upto now, nothing. Forced me to get a case of bd28 from u.s, price is higher than that of volmax, but i know i am going to have them, rather than just wait for volmax stocks
    Dec 2007
    #1894
    Quote Originally Posted by doy View Post
    Yes the OEM has a better efficiency rating, Might check for Donaldson versions of that filter.
    Nov 2007
    #1895
    zz. X- $;..
    Apr 2012
    #1896
    Quote Originally Posted by zix888 View Post
    How much is volmax selling? went their yesterday still no stock. How much then is your filter cost from your computation? tia
    Oct 2011
    #1897
    It seems like it is a case to case basis. Some OEM filters have good fuel filters but bad oil filters and vice versa.
    Oct 2004
    #1898
    Looks like I'll have to search for a Baldwin dealer here or in Davao. Fleetguard for oil and Baldwin for fuel. OEM fuel filter here cost Php 2,500+ which almost 3 times the price of Fleetguard FF5160.
    Dec 2007
    #1899
    You can thank the disaster in Japan for many of the high cost of the OEM items. Lots of those factories were damaged.
    If you know anyone in the state you can get Donaldsons for that filter for pretty cheap.
    P502158 - FC1704 - FUEL FLTR<BR>DONALDSON REPLACEMENT FOR<BR>SAKURA PART# FC1704 - Filter Products
    May 2009
    #1900
    and the OEM fuel filter is standard flow, right?? if it is, maybe i'll go OEM so as not to change also the priming pump.
Remote bypass oil filtration
