Page 145 of 390 FirstFirst ... 4595135141142143144145146147148149155195245 ... LastLast
Results 1,441 to 1,450 of 3899
    #1441
    I just sent a email to fleetguard about that. It's a issue on that fuel filter as well. All filter has flow numbers and I am not sure how those could be meet with a reduction in outlet holes.
    The fuel filter only has 4 holes vs 8 on the US version. and as you stated the LF3564 only has 6 outlet holes vs 10 on the US version.
    The newer version of the FF5160 as even larger holes than the one I posted if you check it on the Cummins site. So that is a concern.
    So Doc, if those bought from W&L and Pacer are Legit LF3564, are they good to use? even though they have 6 holes and the construction is that way? Tried to tear apart the filter media with my hands, it was quiet sturdy...
    Dec 2009
    #1442
    Ry_tower
    ito ata email baldwin international na pinagtanungan ko before
    internationalsales*baldwinfilter.com -- baldwin international
    china*baldwinfilter.com -- baldwin china
    southeastasia*baldwinfilter.com -- baldwin south east asia
    tanling.low*donaldson.com / booncheng.peh*donaldson.com / xindy.ang*donaldson.com -- donaldson
    engine.service.parts*donaldson.com -- another donaldson
    yan ang nakita ko sa sent items nang email ko eh... hope you would have good use for these. hehe.
    Dec 2007
    #1443
    Yes they are but the construction of the filter is clearly different. I will see if I hear back from them about the flow numbers on those fitlers
    #1444
    Thanks Doc, really have to decide if I'm gonna use it or settle with VIC. Volmax is still out of stock with baldwin filters.
    Dec 2007
    #1445
    They are still way better than VIC, the OEM filter has only 4 holes for the fuel and 6 for the oil filter. And I believe that's all VIC has as well. So they could just be making them to meet those specs and not to exceed them.
    #1446
    bg, I'm still using the one I bought sa W&L sa FM ko. You will notice external quality of it when compared sa VIC even when it was initially said na knock off yun nabili natin. Now extend pa ang gamit ko sa kanya since it was confirmed na orig.
    Jan 2011
    #1447
    From the cummins/fleetguard website, LF3564 has a thread pattern of 'M26 X 1.5-6H INT'. Does the 6H indicate the number of holes?
    #1448
    Hi dvldoc. Just want to clarify that the oil filter being offered to me in replacement (the ones with open and close parenthesis)of certain filters at Volmax is ok to use? I guess there is still OOS of BD28 and BD7028.
    Checked the BD7028 and the suggested replacements and this came up in my research. My concer is the PSI difference and slightw weight difference.
    baldwin b7045, lube spin-on
    baldwin bd7028, dual-flow lube spin-on
    B7004(BD7141)
    B1422(B7033)
    BD7159(BD7169)
    B337
    B7045(BD7028)
    BD7095(BD28)
    Dec 2007
    #1449
    B7004(BD7141) Ones a dual flow one is not. Dual flow will have higher rating but the non dual flow will still be 12 microns *50% which is way higher than a VIC.
    B1422(B7033) Go with the biggest that will fit. The B7033 is 103cm long vs 88cm.
    BD7159(BD7169) Bypass valve diffeerence is to great it's 21psi difference you need don't want more than 6 or 7psi difference.
    B7045(BD7028) You could use either of these filters to replace the BD28. The BD7028 has a slightly lower micron rating but still is a quality filter.
    BD7095(BD28) The BD7095 does not have a bypass valve so looks like you can't use it. It's for a vehicle that has a internal bypass switch. Not that you could clog it on with even 15000klm oil changes but I would be cautious.
    Weight difference is not a big deal
    So the BD7028 B7045 will also work on the 4M40, I would keep the B7045 at 10000klm oil changes since it's not a bypass filter.
    #1450
    Thanks bro, yan na nga rin balak + TOP1 SDO.
Remote bypass oil filtration
