Page 224 of 390 FirstFirst ... 124174214220221222223224225226227228234274324 ... LastLast
Results 2,231 to 2,240 of 3899
    #2231
    For Zuk APV G16A engine, BT223 is the largest it could handle. Gasket is larger than OE but spin-on base has the same diameter so no problem.
    #2232
    Been rereading the entire thread again. So apologies if I reviving or quoting other people's old post.
    CB, which L300 did you try it on? Versa Van or FB body?
    This one's the Mitsubishi OEM filter. Don't have the dimension for it so I can't really tell if how does it size up vs. BD28 vs. Bosch OM 036
    I have the bosch OM 36 and BD28 side by side. BD28 is taller by 5 mm or something. Bosch is wider and heavier than BD28. Externally, somewhat better built or put together than BD28. Looked inside the OM 036, the bypass filter looks like a stack of tissue papers. I maybe wrong.
    Has anyone already tried fitting Baldwin on L300FB? I took some measurements last time and i think theres a little clearance for an upgrade. The rear AC plumbing will hit the buttom of the filter.
    As per Volmax, andami daw nagtatanong ng BD28 makulit daw yung lagi tumatawag sa Montero.
    Dec 2007
    #2233
    The BT223 should fit just about all Suzuki 4cly gas engines. Beats the heck out of a Vic C110.
    #2234
    FB body sir.
    G16A is for Vitara right?
    #2235
    ^ Yup, same with APV. Notice the buttom of filter is about the level of the crossmember, going any longer is not recommended.
    May 2005
    #2236
    Bosch OM 036 vs. BD28 (don't sweat, its an new old stock from way before the "shortage").
    Bosch has no crimping and has less holes. Its also wider by a bit vs. the BD28
    Bosch has bottom canister plastic shrink wrap. Both have fluted tops. BD28 slightly narrower but taller.
    Bosch is made in Korea (If I'm not mistaken).
    The Bosch is probably a great replacement to the VIC C306 and if I'm not mistaken its also cheaper at Php 350 a pop. Solidly built and feels heavier than the BD28. I plan to put this in the L300 delivery with 3xx,xxx kms and replace that Vic C306.
    <<<<:D BD28 not for sale or trade :D>>>>
    Oct 2011
    #2237
    Sir dvldoc, I think this is also compatible to 2kd-ftv.
    Dec 2007
    #2238
    Fits all Fortuner, Innova, Hilux 3.0 D4D, 2.5 D4D and 2.7 engines. The 2.7 you can actually go with the larger B34 or B233 filter as well.
    And basically fits all Toyota 4cly and 6cly gas engines from 1995 to present.
    #2239
    for Innova with 2.0 gas engine, you can also use the bigger B233 filter.
    May 2012
    #2240
    Hi everyone! This thread proved to be some heavy reading, but it helped me understand more about oil and oil filters. Kudos!
    Some questions that I have:
    1. Is the BT223/ B233 also applicable for older units of Toyota Corona? Mine is a 3SF engine model.
    2. Also tried looking for cross reference for a B1446 for Isuzu Xwind (4jai1), it seems that the B109 will also fit. Can anyone confirm this? Also for the Xwind, is it advisable to use the Mobile delvac mx 15w 40? Saw one at true value priced at P1184 for the one gallon
    Thanks a lot!
Remote bypass oil filtration
