Page 384 of 390 FirstFirst ... 284334374380381382383384385386387388 ... LastLast
Results 3,831 to 3,840 of 3899
    #3831
    Quote Originally Posted by leoblack9 View Post
    Would a Donaldson P550335 or a Baldwin Bt223 filter last for atleast 15,000kms when paired with a very stout oil like a Mobil Delvac 1 5w40?
    Pretty much everywhere I've read consistent UOAs online that it maintains its TBN at 10,000miles (15~16k kms) and since its also the most expensive diesel oil out there it just feels wasteful to change it out early since I racked up 10,000kms in under 7 months.
    Yes pwede if not so polluted or dusty or the driving is not rated as severe. If it is, best to keep it at 10,000kms between OCI.
    #3832
    good day! can someone kindly confirm that using this oil / oil filter combo, Mobil Delvac MX 15W40 and Baldwin B113 can be used up to 10,000 kms as OCI? Thanks. Also, is Donaldson a good fuel filter? my engine is Isuzu 4JH1-TC.
    Thanks!
    May 2017
    #3833
    Jan 2009
    #3834
    He lost all credibility when he said he’s comparing between the “least expensive conventional oil filter to the most expensive fully-synthetic oil filter”.
    #3835
    What is the Baldwin oil filter for Fortuner 2016 Diesel? What about for Innova 2008 gas? Pareho lang ba?
    #3836
    ^ 1KD/2KD, 1GD/2GD, 2TR engines use the tiny BT233. You may want to cross-ref OE PN#s at Baldwin site just to be sure.
    #3837
    Sir, I read that Baldwin B2 a bigger oil filter may also be used. Is this so?
    What about MANN W940 High Performance, is this also a good filter for Toyota Fortuner and Innova?
    #3838
    Erratum to my previous, should be BT223.
    Quote Originally Posted by attyallanlatras View Post
    Yes you may as long as the thread,gaskets are the same and it fits in the engine, and bypass valve is within specs. Basic principle is the bigger the better because of larger filtering media surface area, filtration is a straightforward/exact science.
    #3839
    Toyota 90915-YZZD2
    Baldwin BT223
    Donaldson P550335
    Baldwin B243^
    Donaldson P550400^
    Baldwin B1405
    Baldwin B178^
    Donaldson P554770^
    ^ long version
    Got the above from my back reads here. How would I be able to verify if the above reference number would fit or be equivalent to toyota oil filter for fortuner?
    #3840
    BT223 or similar-sized should fit without problems, but if you will upgrade- buy some samples or measure the actual vertical clearance to determine if it will fit in the engine without hitting any hose/accessories.
    Sometimes the thread of the spin-on adapter has stand-pipe that you need more clearance for the ing/egress of the filter. Or the diameter won't fit because the spin-on adapter has a lip or the oil cooler does not allow you to go bigger than the OEM. Try backreading more for 2KD who upgraded to bigger filters.
Remote bypass oil filtration
