Results 3,871 to 3,880 of 3897
March 5th, 2019 02:09 PM #3871
- Nov 2009
- 3,484
March 5th, 2019 02:39 PM #3872Around 40k's. the coalesced from oil mist collects at the bottom sometimes drips at the lower ic hose.
March 5th, 2019 03:15 PM #3873
- May 2017
- 2,099
March 19th, 2019 08:13 PM #3874
- Feb 2008
- 898
April 1st, 2019 10:00 AM #3875Sa mga naka install ng Mann-Hummel Provent 200 sa kanilang ride, meron bang kasamang mga hoses (hydraulic) sa Oil Catch Can na yan? O tayo pa ang mag supply?
I found a shop here na nagbebenta ng Provent 200, unit lang pero walang hoses.
Malaki kasi ang diameter yung para sa connection sa hoses (tubes).... Saan kaya maka bili?
- Sep 2008
- 1
May 5th, 2019 04:26 AM #3876Is this real or fake?
- Feb 2008
- 898
June 14th, 2019 07:50 AM #3877After installing a Mann-Hummel Provent 200 oil catch can to my Fortuner 2016 A/T Diesel G variant, and checking the filter element every now and then (most especially after a long drive), I can say that I am very happy and satisfied with this modification since I can really see that the oil catch can really worked as evidenced by the oil that is separated from the air and caught by the filter.... Since the installation is still new, the oil is still in the filter element and not dripping down below the can. There is a hose with a valve attached to the bottom of the oil catch can.
By the way, the oil that I am using is a 10w30 zic fully synthetic oil with a genuine Toyota oil filter and so far so good. I am in quandary if I have to do the change oil every 5000km (6 months interval) or 10,000km (1 year interval) taking into consideration that I have installed an oil catch can?
- Feb 2003
- 1,038
June 14th, 2019 09:39 AM #3878In my Opinion, installing an oil catch can purpose doesn't have an effect on the engine oil change interval naman. What it really does is to prevent or minimize oil gunk or sludge accumulation in the intake manifold and intake valves of the engine. Now if we will really goes into details it somehow improves din naman nga pala kse having a good unobstructed air flow to the combustion system e.g. piston will have a good combustion and less unburned fuel that can seeps into the pistons and contaminate the oil, but that is on the long run and not an immediate effect. I've always been practicing my calculated risk approach based on past observation and experiences and have always been doing an oil change every 10K km or 1 year which ever comes first with the exemption of brand new car first 2years I follow the Casa recommendation during the sensing stage if the car is a lemon or not...after that kahit pa nasa warranty nag 1 year interval na ako irregardless of warning ng service advisor. Bottom line its up to you sir,depending on your risk appetite.
In my old cars>10years na seldomly used using as well ZIC oil I even go further than 1 year, so far no issue naman. Oil still looks good, though I don't have the technical actual specification of the oil condition but my sense tells me oks pa naman. An extended oil interval naman with less mileage risk really lang naman is a high TAN which I don't think with the new mettalurgy of the engine will not really have that much effect on it, sa mga gaskets and seals perhaps. But those are am willing to take the risk.
- Feb 2008
- 898
June 18th, 2019 07:27 PM #3879Sharing some pics on the modification done on my ride (Fortuner 2016 G variant A/T). I have the Provent 200 Oil Catch Can installed after the lapse of the 3 year warranty and so far I am very satisfied as it worked as expected.... driven about 900km from the time I intalled the OCC...
https://i907.photobucket.com/albums/...talled%201.jpg
https://i907.photobucket.com/albums/...talled%202.jpg
https://i907.photobucket.com/albums/...talled%203.jpg
https://i907.photobucket.com/albums/...talled%204.jpg
I was not the one who installed the OCC but a reputable auto shop here in Cebu.....
I would have wanted to post the pics here directly but I do not know how. So links na lang sa PhotobucketLast edited by attyallanlatras; June 18th, 2019 at 07:50 PM.
- Feb 2008
- 898
July 15th, 2019 08:03 PM #3880Mga bossing, sa mga nag-install ng ng Oil Catch Can., me tanong ako.... Every now and then I would be able to get around 30cc of black oil after draining. for the past 2 draining times, I replaced the same amount of new oil back sa engine ko. Tama ba yun? Should I continue this practice of replacing new oil of the same amount na natanggal from the OCC?
