Results 3,851 to 3,860 of 3899
- Mar 2010
- 2,275
February 10th, 2019 09:20 PM #3851
- Nov 2009
- 3,509
February 11th, 2019 11:42 PM #3852
February 12th, 2019 10:56 AM #3853
Who sells Nippon Micro oil filters around the Metro? Any recommendations?
- Mar 2010
- 2,275
February 16th, 2019 03:15 PM #3854
- Feb 2008
- 903
February 28th, 2019 06:50 AM #3855My Innova 2008 model has a gas engine with over 130,000km ODO. Read somewhere about Oil Catch Cans... My questions are: Should I install one (readily available is MANN Provent 200) considering na gas yung engine ko? Marami ba dito nag-install ng ganito? Is it difficult to maintain? Complicated ba ang maintenance to a noob just like me who wants to learn and try it out? Can the maintenance be done during the 5,000km PMS?
- Feb 2008
- 903
February 28th, 2019 10:47 AM #3857
February 28th, 2019 11:14 AM #3858
It depends upon the OCC that you will install. Some are easy yo maintain others are not. But most aftermarket OCC have easy drain plugs. Once a year lang ang drain ng oil niyan.
Just make sure na yung sukat ng intake at nung sa breathet sa valve cover mo ay pareho. Just do some research on the net about OCC to get a better understanding.
Sent from my SM-G965F using TapatalkFasten your seatbelt! Or else...Driven To Thrill!
- Nov 2009
- 3,509
February 28th, 2019 03:19 PM #3859For gasoline, crankcase ventilation is controlled by the PCV valve. You just need to maintain that PCV valve to avoid buildup of gunk and unecessary pressure.
For diesels, crankcase is open directly vented in the air-intake manifold that is why negative pressure amplifies the oil-mist being ingested back to the intake, hence the need to install OCC.
- Feb 2008
- 903
March 2nd, 2019 09:04 AM #3860
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
