Page 127 of 195 FirstFirst ... 2777117123124125126127128129130131137177 ... LastLast
Results 2,521 to 2,540 of 3899
    May 2012
    #2521
    im about to try this baldwin oilfilter on my next oil change.
    Feb 2012
    #2522
    Quote Originally Posted by bayen View Post
    natapos ko din after a week.
    ang haba na ng thread na to. Worth reading. dami ko natutunan.
    Anyone here knows whats the FG or Baldwin part number for Fuel Filter for Honda Jazz 2010?
    Thanks.
    ako isang buwan na yata, nangangalahati pa lamang. hehe. pero tama ka, dami ka matutunan dito. if only easily available yung mga oil filters na highly recommended dito.
    Jan 2012
    #2523
    Quote Originally Posted by gearhead000 View Post
    binebenta na lahat ni dvldoc yung stash nya. madali syang stock ng baldwin at fleetguard and other quality filters. just pm him and am sure he has what filter you need for your ride.
    #2524
    Guys bmay Baldwin oil filter ba for Vios 08? And may mabibilhan na shop sa Banawe? If meron, where? Thanks. I've heard na 15w40 Caltex Delo Gold daw magandang "cleaning" oil? Planning to change kasi from Idemitsu 5w30 to this eh. Sabi sakin wag na raw mag engine flush kasi makakasama pa raw sa makina. TIA po. Sorry daming tanong.
    #2525
    Chiks, baldwin bt223 for toyota. Yan gamit ko sa innova and vios gen2 namin. As for oil, dont use weight 30 oil. I used the idemitsu eco oil before sa vios. Ang pangit ng response.
    #2526
    Thanks. Yup Idemitsu Eco rin gamit ko di ko masyado napapansin difference hehe. Okay na siguro yung 15w40 na Delo Gold, ano? No need to flush na rin ba? Kasi from FS oil to ordinary oil.
    Jan 2012
    #2527
    if you are going to use Caltex Delo I suggest you use Caltex Delo Gold Ultra 15w40 instead of Delo Gold. Gold Ultra has the "safe" amount of Zinc, 1200 PPM. Anything higher than 1200 PPM is not safe for the Catalytic Converter. Mas mura nga lang ng onti yung Gold (215 per liter, i just checked yesterday at a local Caltex shop here in Angeles City. Delo Gold Ultra is at 230 per liter.
    Delo Gold - Zinc * 1500 PPM; API Rating CH-4
    Delo Gold Ultra - Zinc * 1200 PPM; API Rating CI-4 ( Safe for Cat Con)
    #2528
    chiks, problem kasi with idemitsu eco, weight 30 is not suitable for our weather. im currently using Zic brand oil. it was posted here before na ok itong brand and affordable siya. dvldoc also recommended this brand. its the biggest group3 (semi-syn) oil manufacturer around the world.
    bale Zic + baldwin combo gamit ko sa fleet namin. though 5k km OCI parin ako sa mga toyota namin.
    Jan 2012
    #2529
    mga gurus papost naman ulit ng efficiency rating (nominal rating) ng:
    1. BT223
    2. LF3335
    3. Valvoline V0-106
    namention na sakin kanina ni doc nakalimutan kong isulat.
    thanks in advance
    Dec 2007
    #2530
    The bt223 is 98% * 25 microns its nominal rating is 12 microns * 50% so it means on a single pass it will filter out 50% of particles that are down to 12 microns, The fleetguard has the same absoulute rating but they do not publish the nominal rating.
    Valvoline v106 is 98% * 20 microns
    Dec 2007
    #2531
    Valvoline vo106 is 98% * 20 microns. Nominal is 5 microns. You have to call But allmost to get the baldwin microlit media filters are the same rating.
    Jan 2012
    #2532
    Thanks doc.
    read somewhere posted in bob the oil guy LF3335 are 76% * 30 microns? not sure if this is accurate.
    Fleetguard efficiencies - Bob Is The Oil Guy
    Jan 2012
    #2533
    Here are some awesome pictures of cut open BT223. I dont remember anymore if these have already have been posted here.
    Dec 2007
    #2534
    i have posted those before, also the tread you referenced is 10 years old, not a good souce for up to date ratings. I called Fleetguard to get the ratings since they do not publish them.
    Dec 2007
    #2535
    That post from Bob the oil guy is from 2002.
    Dec 2007
    #2536
    The link post is 10 a decade old. Ratings change over time.
    Jun 2005
    #2537
    The ones here are made in Malaysia, i took a look at some already, they are not the same as the US made ones. The other big give away is the plasticc on the bottom of the filter. 5he construction see far. Lighter than the ones from the states. If my tools wlere not all (borrowed) by my in-laws i would cut one open.
    hey doc, so that means the purolator ace is selling is orig? I was still wondering why the L14476 that i had in stock had no crimps and country of origin. i thought it was fake but now im thinking its an asian market version.
    im still using BT223 for my toyota but i still have some purolators. stopped using purolator when their authenticity was questioned. hehehe
    #2538
    bayen, is that yours? hehe
    Jun 2005
    #2539
    guys, quick question, sorry got a little confused reading about good oils in thus thread.
    for a vios, what is the lowest TBN i
    should use? I read the spec sheet pf idemitsu eco 10w-30 from an it had only 7.8. I was thinking its kinda low, is it?
    is zic oil okay for the vios? What series/type do you recommend? I read its a type-III oil so it must be good. Where can i buy it and how much is it?
    im done researching on the oil filters. im now researching on good oils that are relatively low priced with good performance. i plan to use it for about 8k kms only
    Jan 2012
    #2540
    *CB
    no sir. hehehe! repost lang from the other site. ganda kasi ng pics e. ang linaw. nasasayangan din ako kung cut open ko yung unused BT223 ko. hehehe
    * doc
    Found it bro
    http://www.modot.mo.gov/business/con...rposesONLY.pdf
Remote bypass oil filtration
