i just had my oil changed this morning using delo 400 from previous petron trekker, so far less vibration and noise pa lang nararamdaman ko, will keep monitoring![]()
You might want to check with berrimma diessel for some of my fine filters soon, sorry no 4m40 filters in stock yet.
It's the 4m40E1 which I think has a different thread.
WIX FILTER 51798 CASE OF 6 Caterpillar Mitsubishi Isuzu | eBay
WIX 51675/51067 yung puwede sa 4M40 eh."PARTS DETAIL
Principal Application: Caterpillar, Detroit Diesel Engines, Hitachi Excavators, Isuzu H.D. Trucks, Mitsubishi Trucks
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 5.968
Outer Diameter Top: 4.282
Outer Diameter Bottom: Closed
Thread Size: 1 1/8-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=24/45
Burst Pressure-PSI: 420
Max Flow Rate: 18-20 GPM
Nominal Micron Rating: 32
Ganda nga ng micron rating nitong Wix 51675 eh, biruin mo, 6. So 50% efficient at 6 microns. Parang original LF3564.PARTS DETAIL: Wix 51675
Principal Application: Mitsubishi Trucks
Service: Lube
Type: Full Flow/By-Pass
Media: Paper
Height: 5.981
Thread Size: 26X1.5 MM
By-Pass Valve Setting-PSI: 13-16
Nominal Micron Rating: 6
hey doc what you filter do you recommend for a nissan patrol zd30?do you have 1 in stock? thanks
Gleaning from posts from this thread, VIC are actually well built but their filter media they use is quite inefficient.
I dont carry the one for the zd30 but i did post a bunch of examples of brands for that engine. Most were japan brands. The vic and oem were the lowest quality of the lot
The ones here are made in Malaysia, i took a look at some already, they are not the same as the US made ones. The other big give away is the plasticc on the bottom of the filter. 5he construction see far. Lighter than the ones from the states. If my tools wlere not all (borrowed) by my in-laws i would cut one open.
My remote bypass set up installed on my Elgrand.
The black filter is my Luberfiner XL series which is 98.9% efficient at 20 microns and 50% * 5 microns and is a full flow and a full synthetic wire backed synthetic media.
http://www.luberfiner.com/documents/...single-pgs.pdf
And the second is my Fleetguard Venturi combo filter. Basically the best spin on filter you can get for the money period. 98.9% efficient at 20 microns on the full flow and 98.9% efficient at 5 microns on the bypass section.
http://www.cumminsfiltration.com/pdf...LT36043-GB.pdf
http://www.cumminsfiltration.com/pdf...es/LT36043.pdf
I will safely be able to go around 35000klm between oil changes. I'm using Mobil Delvac 1300 super 15w40 with a bottle of zddp plus to get my zinc phosphorus levels to around 1800ppm. Engine is extreamly smooth and the oil only has a light black tint to it. The first 2 days it was still clear.
I will do a oil analysis at 10000k on the oil. Getting a sample is easy I just open up the port on the side of the filter mount.
hey doc, so that means the purolator ace is selling is orig? I was still wondering why the L14476 that i had in stock had no crimps and country of origin. i thought it was fake but now im thinking its an asian market version.
im still using BT223 for my toyota but i still have some purolators. stopped using purolator when their authenticity was questioned. hehehe
Has anyone tried SEAOIL DEO Max 15W40? It seems on their website that it's a pretty good oil. Already a CI rated oil. And the TBN on this thing is a Min of 13!
Exceeds:
API CI-4/CH-4/CG-4/CF/SL
ACEA A3/B4/E3/E7
VOLVO VDS-3
MB P 228.3
MACK E0-M PLUS
GLOBAL DHD-1
MAN M3275
CUMMINS 20071/2/6/7/8
Caterpillar ECF-1a
MTU Oil Category2
Typical Physical Properties Unit SAE 15W40
Density * 15.6 C kg/l 0.894
Viscosity * 40 C cSt 110.00
Viscosity * 100 C cSt 14.50
Viscosity Index --- 134.00
Flash Point, COC C 206.00
Total Base Number mg KOH/g 13-15
SEAOIL Philippines, Inc. - LubricantsDEO
