Page 123 of 195 FirstFirst ... 2373113119120121122123124125126127133173 ... LastLast
Results 2,441 to 2,460 of 3899
    Mar 2012
    #2441
    You might want to check with berrimma diessel for some of my fine filters soon, sorry no 4m40 filters in stock yet.
    The Caterpillar 307B excavator uses the 4M40 engine. The CAT dealer or heavy equipment parts stores might have the oil filter for this engine.
    Quote Originally Posted by Rocko24 View Post
    It's the 4m40E1 which I think has a different thread.
    WIX FILTER 51798 CASE OF 6 Caterpillar Mitsubishi Isuzu | eBay
    "PARTS DETAIL
    Principal Application: Caterpillar, Detroit Diesel Engines, Hitachi Excavators, Isuzu H.D. Trucks, Mitsubishi Trucks
    Style: Spin-On Lube Filter
    Service: Lube
    Type: Full Flow
    Media: Paper
    Height: 5.968
    Outer Diameter Top: 4.282
    Outer Diameter Bottom: Closed
    Thread Size: 1 1/8-16
    By-Pass Valve Setting-PSI: None
    Beta Ratio: 2/20=24/45
    Burst Pressure-PSI: 420
    Max Flow Rate: 18-20 GPM
    Nominal Micron Rating: 32
    WIX 51675/51067 yung puwede sa 4M40 eh.
    PARTS DETAIL: Wix 51675
    Principal Application: Mitsubishi Trucks
    Service: Lube
    Type: Full Flow/By-Pass
    Media: Paper
    Height: 5.981
    Thread Size: 26X1.5 MM
    By-Pass Valve Setting-PSI: 13-16
    Nominal Micron Rating: 6
    Ganda nga ng micron rating nitong Wix 51675 eh, biruin mo, 6. So 50% efficient at 6 microns. Parang original LF3564.
    #2443
    i think there are other resellers of baldwin in caloocan. just this morning, i saw a guy in a motorcycle along c-3 road. and there is a baldwin logo printed on his shirt. wasnt able to get the company name on the front of his shirt though. he's wearing a blue shirt.
    #2444
    Hi doc just wanna ask if baldwin b1446 is the correct filter for my isuzu 4JA1 n/a engine? i'm going baldwin all the way... hehehe
    Dec 2007
    #2445
    Yes that one works as well as the fleetguard lf3528 which i have lilike 70 of them at the house here.
    #2446
    If I cant source baldwins b1446 in caloocan, i 'll drop by berima. thats where you had them at stock right? Berima is too far from me...
    Dec 2007
    #2447
    i LBC
    Jan 2008
    #2448
    *doc,
    amen!
    #2449
    i LBC
    That's great Doc, I'll send you a PM on my next oil change .. If I use LF3528 on delo Gold, would it be good for 7000K for a 1 year use? can't seem to find delo 400 on auto supplies... delo gold has isosyn ...
    Jan 2012
    #2450
    Okay ba vic filters?
    Aug 2005
    #2451
    hey doc what you filter do you recommend for a nissan patrol zd30?do you have 1 in stock? thanks
    Dec 2007
    #2452
    I dont carry the one for the zd30 but i did post a bunch of examples of brands for that engine. Most were japan brands. The vic and oem were the lowest quality of the lot
    Jun 2005
    #2453
    Quote Originally Posted by carwhacko View Post
    try to backread. that question has beem asked and answered and debated a lot of times.
    short answer, No
    May 2005
    #2454
    Gleaning from posts from this thread, VIC are actually well built but their filter media they use is quite inefficient.
    Jan 2012
    #2455
    Oh okay thank ou sir
    May 2012
    #2456
    Has anyone tried SEAOIL DEO Max 15W40? It seems on their website that it's a pretty good oil. Already a CI rated oil. And the TBN on this thing is a Min of 13!
    Exceeds:
    API CI-4/CH-4/CG-4/CF/SL
    ACEA A3/B4/E3/E7
    VOLVO VDS-3
    MB P 228.3
    MACK E0-M PLUS
    GLOBAL DHD-1
    MAN M3275
    CUMMINS 20071/2/6/7/8
    Caterpillar ECF-1a
    MTU Oil Category2
    Typical Physical Properties Unit SAE 15W40
    Density * 15.6 C kg/l 0.894
    Viscosity * 40 C cSt 110.00
    Viscosity * 100 C cSt 14.50
    Viscosity Index --- 134.00
    Flash Point, COC C 206.00
    Total Base Number mg KOH/g 13-15
    SEAOIL Philippines, Inc. - LubricantsDEO
    #2457
    Quote Originally Posted by Arj_11 View Post
    Exceeds:
    ACEA A3/B4/E3/E7
    VOLVO VDS-3
    MB P 228.3
    MACK E0-M PLUS
    GLOBAL DHD-1
    MAN M3275
    Caterpillar ECF-1a
    MTU Oil Category2
    i havent tried it yet cause last time i checked, its was priced higher than Delo. Though Dvldoc posted earlier that anything with the Cummins rating should be good.
    May 2012
    #2458
    Any idea on the cost per liter?
    Aug 2005
    #2459
    thanks doc will have to burn the midnight oil to look for it
    May 2009
    #2460
    Exceeds:
    ACEA A3/B4/E3/E7
    VOLVO VDS-3
    MB P 228.3
    MACK E0-M PLUS
    GLOBAL DHD-1
    MAN M3275
    Caterpillar ECF-1a
    MTU Oil Category2
    looks good based sa service classification at tbn.
Remote bypass oil filtration
