Results 1,361 to 1,370 of 3899
March 3rd, 2012 07:46 PM #1361
March 3rd, 2012 08:14 PM #1362
petron doesn't have any available MSDS or even product data sheet... caltex and shell has their PDS available in the internet...
makes you really wonder why petron doesn't divulge whats in their oil.... for the same price that trekker sells, you can buy a good oil that has a good additive and PDS available...
i have never been a fan of petron especially their hauler and trekker series...
- Jun 2005
- 3,774
March 3rd, 2012 08:30 PM #1363
March 3rd, 2012 09:04 PM #1364
Why that lying s..... :D Well he told me two days ago that they didn't have any more stocks of the B28 bec. the people from the forums cleaned him out.
Well its a good thing he didn't sell it to me. :D
Now I don't know what filter to use for our fleet of L300 FBs.
Check this : Baldwin Filters E-Catalog
USDM Yaris only uses 1NZ-FE (1.5) and according to Baldwin's site, B33 is the one you should use.
March 3rd, 2012 10:43 PM #1365
^ sir use the Bosch filter na lang for your 4d56. At least guaranteed better performance than OEM and Vic but almost thrice cheaper.
Fasten your seatbelt! Or else...Driven To Thrill!
March 3rd, 2012 10:57 PM #1366
BT223 fits all 4cly toyota gas engines and gives you a bit more filtering surface, cars can use a variety of sizes of filters you can go bigger you can go smaller, it just needs to have the same thread pattern, same bypass valve range, burst pressure, and flow numbers. The BT223 flows more than the B33, is slightly bigger, same bypass valve, same burst pressure so it's the better filter. They do not have the B33 in stock.
I'm surprised to see the BD28 would not fit the L300's it's to bad you would figure they would have the clearance since it's smaller than the stock filter unless your ride is converted? The Bosch filter for the 4D56 is like 1.5" taller and it's wider so that's out the door for you to.
The JS catalog also says BD28 for the L300, perhaps your frame has a issue,
JS Filters :: Application Cross Reference and Image for JS : Oil (Spin-on) : C306J
The JS filter is 125mm long the BD28 is 136mm, that's only 10mm which is only a 0.39 inch difference.
* number001 measure your current filters and the space. All you need is 136mm of space.Last edited by dvldoc; March 3rd, 2012 at 10:59 PM.
March 3rd, 2012 11:30 PM #1367
March 3rd, 2012 11:35 PM #1368
March 3rd, 2012 11:44 PM #1369
Looks like you have a good inch to play with there. Best bet would be to try a BD28, Get if from the guy who cannot now use it because it does not fit.
March 3rd, 2012 11:47 PM #1370
Thanks, I checked them out pero walang Michelin Ang laki ng difference ng price sa Jiga....
Finding the Best Tire for You
