Been rereading the entire thread again. So apologies if I reviving or quoting other people's old post.
CB, which L300 did you try it on? Versa Van or FB body?
This one's the Mitsubishi OEM filter. Don't have the dimension for it so I can't really tell if how does it size up vs. BD28 vs. Bosch OM 036
I have the bosch OM 36 and BD28 side by side. BD28 is taller by 5 mm or something. Bosch is wider and heavier than BD28. Externally, somewhat better built or put together than BD28. Looked inside the OM 036, the bypass filter looks like a stack of tissue papers. I maybe wrong.
FB body sir.
For Zuk APV G16A engine, BT223 is the largest it could handle. Gasket is larger than OE but spin-on base has the same diameter so no problem.
G16A is for Vitara right?
