Been rereading the entire thread again. So apologies if I reviving or quoting other people's old post.
just a heads up for all people wanting to buy BD28 for their 4D56 powered L300, it will not fit!! cause the filter is 0.5in longer and it is hitting the chassis and cant place it in anymore..
CB, which L300 did you try it on? Versa Van or FB body?
This one's the Mitsubishi OEM filter. Don't have the dimension for it so I can't really tell if how does it size up vs. BD28 vs. Bosch OM 036
The Bosch filter for the 4D56 is like 1.5" taller and it's wider so that's out the door for you to.
I have the bosch OM 36 and BD28 side by side. BD28 is taller by 5 mm or something. Bosch is wider and heavier than BD28. Externally, somewhat better built or put together than BD28. Looked inside the OM 036, the bypass filter looks like a stack of tissue papers. I maybe wrong.
