Page 112 of 195 FirstFirst ... 1262102108109110111112113114115116122162 ... LastLast
Results 2,221 to 2,240 of 3899
    #2221
    Quote Originally Posted by kompressor View Post
    THANK YOU THANK YOU! I just called the number and presto, might head there after work if not tomorrow morning. (They're open 8am-5pm on Saturdays as well)
    better check if they have stock of the filter you're planning to buy first.
    #2222
    wala pa rin bang stock ng BD28 ke Volmax? Hotcakes na yan ah!
  3. #2223
    Yep already did and they actually know and even recommend other Baldwin product numbers that are compatible or matched to engines or other brand product numbers. And I can't believe the prices! I can safely conclude that Baldwins are truly bang for the buck! Mas mura pa ang pricing compared to the overrated VIC!
    #2224
    wala parin BG. hindi pa daw dumadating stocks nila.
    #2225
    or hindi pa malaman kung magkano ang itataas nila sa presyo
    ^ yun lang. hehe
    May 2005
    #2227
    Well here's what Fleetguard sent me.
    Anyone who has a questionable filter they would like to be contacted, Pics and a invoice of purchase helps out a lot.
    These are the photos they sent of the filter.
    doc, those pictures sent to you by Fleetguard of the LF3564 does not appear similar to the 3D model they show in their website. http://catalog.cumminsfiltration.com...&PartType=Lube, Combination&partflag=0&currentPage=1
    -10 holes vs 6 holes.
    -Different design below Fleetguard logo esp." LUBE FILTER LF3564 ". The website 3D shows them as in bolder letters.
    -The website model shows it being MADE IN ARGENTINA.
    May 2005
    #2228
    Been rereading the entire thread again. So apologies if I reviving or quoting other people's old post.
    just a heads up for all people wanting to buy BD28 for their 4D56 powered L300, it will not fit!! cause the filter is 0.5in longer and it is hitting the chassis and cant place it in anymore..
    CB, which L300 did you try it on? Versa Van or FB body?
    This one's the Mitsubishi OEM filter. Don't have the dimension for it so I can't really tell if how does it size up vs. BD28 vs. Bosch OM 036
    The Bosch filter for the 4D56 is like 1.5" taller and it's wider so that's out the door for you to.
    I have the bosch OM 36 and BD28 side by side. BD28 is taller by 5 mm or something. Bosch is wider and heavier than BD28. Externally, somewhat better built or put together than BD28. Looked inside the OM 036, the bypass filter looks like a stack of tissue papers. I maybe wrong.
    May 2005
    #2229
    Update lang.
    Here is the VIC to Baldwin Cross reference.
    C010 B178
    C019 B7045/BD28/BD7028/BD7160
    C025 B114
    C101 B2/B34/B233
    C102 B113
    C103 B34/B223
    C104 B295
    C106 BT223/B33
    C107 BT221
    C110 B33/BT223/
    C111 BT223/B33/B37
    C112 BD7029
    C113 B37/BT223/B33
    C115 BD7029
    C120 B113
    C201 B295
    C204 BT292
    C205 B295
    C206 B34/B223/
    C207 B113/BT223/B159
    C208 B113
    C209 B2/B34/B233
    C209L B118
    C211 B7049
    C212 B45
    C219 B236
    C301 B141
    C302 B302
    C303 B173-S
    C304 B179
    C305 BT338
    C306 BD28/BD7028/BD7095
    C307 B179
    C313 BD28/BD7028/B7045
    C318 B7121
    C401 B7279
    C402 B166
    C404 B7144
    C406 B161-S
    C407 B173-S
    C409A BT223/B33/B37
    C412 BD7160/BD28/BD7028/B7045
    C413 B1402/B1400
    C415 B1402/B1400
    C501N B113
    C502 B7273
    C503 B109
    C504 B109
    C505 B295
    C506 B201S
    C507 BD142
    C509A B72
    C510A B211
    C511 B775
    C512 B7273
    C512 B7273
    C513 B1422 or B7033
    C516 BD7141 or BD7169
    C518/C526 BD7169
    C525 BD7004
    C703A BT223
    C703A B7290
    C803 B166
    C804 B156
    C805 B161-S
    C806 B1402/B1400
    C806 B1402/B1400
    C807 B7284
    C809 B1402/B1400
    C901 B1400/B1402
    C931 B159/BT223
    C931 B159/BT223
    C932 B7165
    C933 BT223/B33/B37
    F103 PF7550
    FC158 BF7535
    FC321 BF7534
    FC409 BF7534
    C409A BT223/B33/B37
    This particular entry is erroneous. JS Filters :: Application Cross Reference and Image for JS : Oil (Spin-on) : C409J
    It should be B7144 or B7130.
    C409A = LF3665 = Wix 51725
    B7144 = LF3642 = Wix 57411
    B7130 = LF3752 = Wix 51725
    Dec 2007
    #2230
    doc, those pictures sent to you by Fleetguard of the LF3564 does not appear similar to the 3D model they show in their website. http://catalog.cumminsfiltration.com...&PartType=Lube, Combination&partflag=0¤tPage=1
    Well the Fleetguard emailed me those pictures saying they were made in Malaysia but, Frankly I would not use them, the quality is much lower than a normal Fleetguard. And they still don't have a country of origin on the filter. Now will they work, yeah probably but rather use a Bosch then that one.
    Another thing the bottom half is supposed to be microglass but it looks nothing like Fleetguards standard microglass media.
    12vdc got this at Pacer and cut it open. It's the real deal and made in the US that other one the media is way to thin.
    Microglass is also steel mesh backed and that filter is clearly not.
    This is a close up of Microglass media. The copper thing is a US Penny to give a reference. You can see the so called Malaysian filter does not even come close on the quality.
    #2231
    For Zuk APV G16A engine, BT223 is the largest it could handle. Gasket is larger than OE but spin-on base has the same diameter so no problem.
    #2232
    Has anyone already tried fitting Baldwin on L300FB? I took some measurements last time and i think theres a little clearance for an upgrade. The rear AC plumbing will hit the buttom of the filter.
    As per Volmax, andami daw nagtatanong ng BD28 makulit daw yung lagi tumatawag sa Montero.
    Dec 2007
    #2233
    The BT223 should fit just about all Suzuki 4cly gas engines. Beats the heck out of a Vic C110.
    #2234
    FB body sir.
    G16A is for Vitara right?
    #2235
    ^ Yup, same with APV. Notice the buttom of filter is about the level of the crossmember, going any longer is not recommended.
    May 2005
    #2236
    Bosch OM 036 vs. BD28 (don't sweat, its an new old stock from way before the "shortage").
    Bosch has no crimping and has less holes. Its also wider by a bit vs. the BD28
    Bosch has bottom canister plastic shrink wrap. Both have fluted tops. BD28 slightly narrower but taller.
    Bosch is made in Korea (If I'm not mistaken).
    The Bosch is probably a great replacement to the VIC C306 and if I'm not mistaken its also cheaper at Php 350 a pop. Solidly built and feels heavier than the BD28. I plan to put this in the L300 delivery with 3xx,xxx kms and replace that Vic C306.
    <<<<:D BD28 not for sale or trade :D>>>>
    Oct 2011
    #2237
    Sir dvldoc, I think this is also compatible to 2kd-ftv.
    Dec 2007
    #2238
    Fits all Fortuner, Innova, Hilux 3.0 D4D, 2.5 D4D and 2.7 engines. The 2.7 you can actually go with the larger B34 or B233 filter as well.
    And basically fits all Toyota 4cly and 6cly gas engines from 1995 to present.
    #2239
    for Innova with 2.0 gas engine, you can also use the bigger B233 filter.
    May 2012
    #2240
    Hi everyone! This thread proved to be some heavy reading, but it helped me understand more about oil and oil filters. Kudos!
    Some questions that I have:
    1. Is the BT223/ B233 also applicable for older units of Toyota Corona? Mine is a 3SF engine model.
    2. Also tried looking for cross reference for a B1446 for Isuzu Xwind (4jai1), it seems that the B109 will also fit. Can anyone confirm this? Also for the Xwind, is it advisable to use the Mobile delvac mx 15w 40? Saw one at true value priced at P1184 for the one gallon
    Thanks a lot!
Remote bypass oil filtration
