Results 1,981 to 1,990 of 3899
May 5th, 2012 07:09 PM #1981
May 5th, 2012 09:32 PM #1982
kung warranty pa, you should follow the recommended interval.. pag hindi na warranty better research if your model is a sludge former so that you don't extend your drain... pwede naman extended drain interval pero from what i know gradual kasi dapat so you'll know how you chosen oil and filter will perform during extended drain intervals...
- Nov 2011
- 86
May 6th, 2012 09:54 AM #1983
May 6th, 2012 12:39 PM #1984
Yes you could that's if you can find one there for that vehicle. You got to remember these are small displacement engines they are not 6 liter V8 turbo diesels, 12000kms is only 8000 miles. When you double the efficiency and dirt holding capacity of the filter which you will by switching a Baldwin then 12000kms is not a long run on full synthetic group IV oil.
It also carries the Cummins CES 20078 / 20077 / 20076 rating which is for extended drain intervals of 12000 miles/ 18000kms.
When you see that Cummins rating your good to go with extended oil change intervals. Due to the fuel quality in the Philippines I would keep it at 12000kms for a good safe oil change interval. This 5000kms is just madness and based on oil change intervals that are outdated on vehicles like that because oil have change a lot since the early 90's.
The Cummins rating will also almost have a TBN of 12 or more. Mobil TDT only has a 10.7 plus it's viscosity at 40C and 100C are clearly inferior and also don't meet Cummins standards.
Mobil MX
SAE Grade 15W-40
Viscosity, ASTM D 445
cSt * 40ºC 123
cSt * 100ºC 15.6
CCS, cP, ASTM D 5293 6000 * -20ºC
MRV, cP, ASTM D 4684 29,000 * -25°C
HTHS * 150ºC, cP, ASTM D4683 4.3
Viscosity Index, ASTM D 2270 133
Sulfated Ash, wt%, ASTM D 874 1.3
Total Base #, mg KOH/g, ASTM D 2896 12
Pour Point, ºC, ASTM D 97 -30
Flash Point, ºC, ASTM D 92 230
Density * 15ºC kg/l, ASTM D 4052 0.879
Mobil TDT
SAE Grade 5W-40
Viscosity, cSt (ASTM D445)
* 40ºC 97.9
* 100ºC 14.5
Viscosity Index 153
Phosporous (ASTM D4951) 0.11
HTHS Viscosity, mPa•s * 150ºC (ASTM D4683) 3.8
Sulfated Ash, wt% (ASTM D874) 0.95
Total Base #, mg KOH/g (ASTM D2896) 10.7
Flash Point, ºC (ASTM D92) 215
Density * 15.6ºC g/ml (ASTM D4052) 0.85
Anything with the Cummins rating feel free to use up to 12000kms, if you want to go further just do a oil analysis and it will tell you how much further you could go.
- Nov 2011
- 86
May 6th, 2012 01:05 PM #1985
May 7th, 2012 10:19 PM #1986
- Sep 2011
- 241
May 7th, 2012 10:23 PM #1987
Surprised that the TBN nung MX is 12, I think those are the US spec sheets since synthetic ata yun but dito sa Asia mineral lng po ata thats why TBN is 10
Mobil Delvac MX 15W-40 USA
Mobil Delvac MX 15W-40 Singapore
- Sep 2011
- 241
May 7th, 2012 10:29 PM #1988Surprised that the TBN of MX is 12, US specs po ata yun since synthetic , yng sa Asia 10 lng po since mineral sya
May 8th, 2012 12:22 AM #1989
For some reason they pulled thier msds sheets from the site, Even the link is dead. http://www.royalpurple.com/prod-pdfs/motor-oil-ps.pdf
Sorry I don't know how to post these in proper format.
40 DD 10W30D 15W40**
CF-2 CH-4/SJ CH-4/SJ
CI-4/SL CI-4/SL
D-445 Viscosity
cSt * 40°C 138.9 67.3 110.1
cSt * 100°C 15.0 10.9 14.9
SSU *100°F 725 344 567
SSU * 210°F 100 62 79
D-2270 Viscosity Index 108 144 140
D-92 Flash Point °F 460 400 435
D-92 Fire Point °F 510 450 470
D-97 Pour Point °F -40 -56 -44
D-2896 Total Base No. 7.5 10.0 10.5
D-874 Sulfate Ash % 0.72 — —
D-4951 Zinc, ppm 812 — —
0W40**** 5W20** 5W30** 5W40**** 10W30** 10W40 15W40*** 20W50
SM/CF SL SL SM/CF SL CG-4, CH-4 CG-4, CH-4 CF/SJ ASTM TESTS CI-4/SL CI-4/SL
D-445 Viscosity
cSt * 40°C 79.9 49.5 65.3 93.7 70.3 94.0 110.1 170.0
cSt * 100°C 14.3 8.7 11.0 15.7 10.8 14.0 15.3 20.2
SSU *100°F 395 253 332 476 360 482 567 880
SSU * 210°F 74 56 64 82 63 75 79 102
D-2270 Viscosity Index 182 156 157 179 140 148 140 138
D-4684 Pumping Viscosities
cP * -40°C 20,000 — — — — — — —
cP * -35°C — 22,200 34,800 21,500 — — — —
cP * -30°C — — — — 18,200 14,900 — —
cP * -25°C — — — — — — 15,200 —
cP * -20°C — — — — — — — 18,800
D-92 Flash Point °F 465 455 440 425 430 400 450 435
D-92 Fire Point °F 495 480 480 470 480 435 470 470
D-2896 Total Base No. 11 12 12 11 12 12.0 10.5 10.5
GASOLINE ENGINES — Typical Properties*
30 40 50
ASTM TESTS CF,CF-2/SJ CF,CF-2/SJ CF,CF-2/SJ
D-445 Viscosity
cSt * 40°C 79.0 121.0 182.0
cSt * 100°C 10.6 14.2 18.6
SSU *100°F 408 631 955
SSU * 210°F 63 74 92
D-2270 Viscosity Index 119 113 113
D-92 Flash Point °F 460 460 460
D-92 Fire Point °F 515 515 515
D-2896 Total Base No. 10.5 10.5 10.5
May 8th, 2012 11:56 AM #1990
^Thanks for the advise guys. Already replaced all.
Rubber boot question (repair or replace)
