Originally Posted by
dvldoc
Yes you could that's if you can find one there for that vehicle. You got to remember these are small displacement engines they are not 6 liter V8 turbo diesels, 12000kms is only 8000 miles. When you double the efficiency and dirt holding capacity of the filter which you will by switching a Baldwin then 12000kms is not a long run on full synthetic group IV oil.
It also carries the Cummins CES 20078 / 20077 / 20076 rating which is for extended drain intervals of 12000 miles/ 18000kms.
When you see that Cummins rating your good to go with extended oil change intervals. Due to the fuel quality in the Philippines I would keep it at 12000kms for a good safe oil change interval. This 5000kms is just madness and based on oil change intervals that are outdated on vehicles like that because oil have change a lot since the early 90's.
The Cummins rating will also almost have a TBN of 12 or more. Mobil TDT only has a 10.7 plus it's viscosity at 40C and 100C are clearly inferior and also don't meet Cummins standards.
Mobil MX
SAE Grade 15W-40
Viscosity, ASTM D 445
cSt * 40ºC 123
cSt * 100ºC 15.6
CCS, cP, ASTM D 5293 6000 * -20ºC
MRV, cP, ASTM D 4684 29,000 * -25°C
HTHS * 150ºC, cP, ASTM D4683 4.3
Viscosity Index, ASTM D 2270 133
Sulfated Ash, wt%, ASTM D 874 1.3
Total Base #, mg KOH/g, ASTM D 2896 12
Pour Point, ºC, ASTM D 97 -30
Flash Point, ºC, ASTM D 92 230
Density * 15ºC kg/l, ASTM D 4052 0.879
Mobil TDT
SAE Grade 5W-40
Viscosity, cSt (ASTM D445)
* 40ºC 97.9
* 100ºC 14.5
Viscosity Index 153
Phosporous (ASTM D4951) 0.11
HTHS Viscosity, mPa•s * 150ºC (ASTM D4683) 3.8
Sulfated Ash, wt% (ASTM D874) 0.95
Total Base #, mg KOH/g (ASTM D2896) 10.7
Flash Point, ºC (ASTM D92) 215
Density * 15.6ºC g/ml (ASTM D4052) 0.85
Anything with the Cummins rating feel free to use up to 12000kms, if you want to go further just do a oil analysis and it will tell you how much further you could go.
