Results 2,011 to 2,020 of 3899
May 9th, 2012 08:29 PM #2011
Bro, basically pag nag pa oil analysis ang tinitignan is Elemental wear analysis, yung mga iron,lead,copper,silicon,chromium etc, na nasa oil mong ginamit, para malaman ang wear sa engine, pero it needs to be done in pattern, kung isang beses lang oil analysis hindi kasi conclusive unless na several times at regular interval ang analysis para meh mag emerge na pattern...
tapos yung TBN (total base number), kung ilan pa natitira na TBN to fight the acidity
then kung gusto mo pwede din yung (TAN) total acid number naman,
Then lastly yung mga fuel count at soot count at coolant count on the oil...
May 9th, 2012 08:36 PM #2012
ang bilis kasi na over shadow ang CI-4 plus nang CJ-4....
minadali kasi yung Oil category na toh for the fast changing emission regulations which the engine manufacturers can't cope with.... it was designed in parallel during the development of many engines, so nung natapos design nung mga engines, the oil category is now late for emission standards...
CI-4 plus is definitely created and intended to extend oil change and improve soot handling on engines requiring that specification.
May 9th, 2012 09:02 PM #2013
Got a response from Royal Purple Technical Manager for international markets. Will post it tomorrow, am on mobile now. Basically, what he is saying was that CJ-4 oils are okay for 500ppm diesel fuels (Euro II, which the Big 3 has) as the TBN is still within 20x of the sulfur content. That makes using Euro IV fuels (Unioil and Eastern) much much better. But since CI-4+ oils has a bit more of the anti-wear properties, it is still preferred to use this for additional engine protection. But for protecting both our engines and the environment, CJ-4 should be the choice...cheers
May 9th, 2012 10:13 PM #2014
May 10th, 2012 10:04 AM #2015
May 10th, 2012 12:33 PM #2017
actually, yung post ni miko regarding sa oil selection is a quick guide. 1-2 pages back ata.
1. sulfur content in diesel oil (500 ppm ang boundary usually)
2. emissions-compliant ba yung vehicle (DPF, SCR, EGR, etc.)
May 10th, 2012 12:49 PM #2018
May 10th, 2012 01:02 PM #2019
^^or sariling compilation mo yung data na yan.....makagawa nga rin ako ng local file ko. sa tagal kong nagresearch dito eh diko naisip yan. puros download lang ng pdf etc. hehehe
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
