Page 299 of 390 FirstFirst ... 199249289295296297298299300301302303309349 ... LastLast
Results 2,981 to 2,990 of 3899
    Jul 2012
    #2981
    okay thanks dvldoc.
    Dec 2009
    #2982
    Guys i still have one piece of bd28... Pm nyo ako if interested...
    Nag iisa na lang... Sayang naman, matatagalan pa uli bago meh dumating..
    May 2005
    #2983
    Anyone interested with BD28? I have three available. PM me.
    Sorry OT
    Jan 2011
    #2984
    Hehe...got 2 LF3564 bought from filterbarn US, PM me for those who want it...hindi kasya sa rig ko tumatama sa intercooler hose kasi...mas wider sya compared sa BD28
    #2985
    mukhang marami nang supply ng BD28... hehehe :banana2:
    #2986
    subukan niyo tumawag sa volmax. 2 weeks ago sabi sa akin may bagong dating daw na container e. hindi ko palang nadaanan last week.
    #2987
    dvldoc
    Hi dvldoc. I need some help here. I would want to run a filter relocation modification BUT the housing for the filter is small. Current or correct filter being used is a bd7160 but gasket diameter for the filter relocation would be able to fit a B2 diameter. Here is the data on the two filters.
    B2:
    Contains: Anti-Drainback Valve
    8 PSID Front End By-Pass Valve
    Descriptions: Dual-Flow Lube Spin-on
    BD7160:
    Contains: 11-17 PSID By-Pass Valve
    I can't remember if I can run a higher or lower psid filter.
    Thanks in advance for your help!
    Dec 2007
    #2988
    Quote Originally Posted by edtf View Post
    dvldoc
    B2:
    BD7160:
    I think you have your filter number mixed it's not a B2 maybe you mean a BD28. The gaskets on those two are different the thread pitch is the same. It may or may not work due to the gaskets size difference you might have a leak.
    - - - Updated - - -
    dvldoc
    B2:
    BD7160:
    #2989
    - - - Updated - - -
    Sorry incomplete info. Thread pitch will not matter and I know filters have different pitch. The relocator has replaceable pedestal (I can't remember what you call the thing you screw your filter on.) so I can use either pitch what I need is for the gasket to hit the lip. The b2 seals on the lip well but has a lowered psid. You think I can use the b2 to replace the original filter?
    Sent from my GT-I9100 using Tapatalk 2
    #2990
    Quote Originally Posted by tuazon7 View Post
    bro nakunan mo ba ng picture yung LF na sasayad sa hose?
    my 2 boxes(24pcs)of bd28 naman sold out din. good kung mgkakasupply sa volmax, para hindi na ako mahirapan magparating
Remote bypass oil filtration
