Page 23 of 195 FirstFirst ... 131920212223242526273373123 ... LastLast
Results 441 to 460 of 3899
    May 2011
    #441
    Quote Originally Posted by vhronx View Post
    *dvldoc,
    Can you comment on Magnetized Oil Trap? is it effective? can it help on the cleaning of dirt in oil?
    I read a column about it and there are some makers like The Bear Trap and FILTERMAG. In that column, it says also that you can use a magnet from the PC Hard Disk.
    you can make a similar gadget like installing a loud speaker magnet at the end cap of the oil filter or a strip of flexible magnet like the one you can get out of refrigerator door around the oil filter. there had been cars with magnetic drain plug. you can also purchase after market magnetic drain plugs. this however, only takes care of ferrous debris. the worst enemy of engine lubrication is still sludging from overcooled engines and prolonged service intervals
    #442
    And to squeeze a little bit more filtration for you peso try a used hard drive magnet, They are super cheap if not free and damm strong.
    Every little bit helps, You can also toss on on the Trans pan and oil pan. You can't beat free or super cheap. Should be plenty of dead hard drive you can get your hands on.
    *dvldoc, will more magnet be better?
    Just bought a Bosch 306 filter. Much more designed for 4d56 engine but in the box it says ok for 4m40 so i got it. Just for P312. Will replace the Vic filter asap. and then I will open the Vic filter to see what's inside. I have run almost 2,700kms on the Vic for 3 months so I guess it worth to try it.
    Dec 2007
    #444
    The more the better, I like one on the bottom and a few on the sides of the filter. The amount of stuff caught should actually go down from oil change to oil change. If it does't it means your getting a lot of wear in your engine.
    #445
    thanks. I just have started to get all the magnet from all the defective hard disk. I can also put some in the trans pan and oil pan.
    Apr 2011
    #446
    Just FYI, The Isuzu trooper with the 4JX1 has a bypass oil system on it.
    The LF16267 will replace your VIC C-524 (the bypass filter) which is your primary. The LF3462 replaces your secondary which is a VIC C-307 (the full flow filter)
    Alternative part numbers are Baldwin B1400 and Fleetguard LF3692 to replace the secondary. No other cross over to the primary filter.
    If you are using VIC the system is pretty much worthless considering how poor they actually filter out anything smaller than 40 microns.
    my question is can we use a combo style filter like Bd28,bd7160 and
    bd7095 and lf3564?cuase i still have some space for 1 inch
    what is the advantage of having combo filter than a regular full flow filter..
    is vic c524 filter is combo filter?
    * ry_tower
    combo filter ba yung nabili mo?saan mo nabili
    Feb 2003
    #447
    Just make sure na all of those magnets will be the heavy duty type or high strength magnets. If you use the less strength magnets and it was accidentally taken/fall off then you have now a hefty chunk of ferrous materials now loose in your pans.
    Cons of having it all sticked to your pans is you have to open up your oil pans in periodic intervals just to check and clean those accumulated ferrous materials, you don't wan't it to be just being collected there in long periods of time waiting for it to be freed from those magnetic flux and a sudden release will overwhelm your oil filtration.
    it is best to put na lang in around the Oil Filter or stick to the Drain plug lang.
    If there will be some entrepraneural motorheads na magbenta dito nyan...I'll get two pcs.
    Dec 2007
    #448
    Quote Originally Posted by asher25 View Post
    * ry_tower
    You should only use what crosses over, If your stock filter is a full flow then you use a full flow. But if it crosses to a combo filter use a combo filter. The VIC C524 is a full flow filter.
    VICS SITE
    Eiken.Co.Ltd.
    * ry_tower
    Sir dito lang sa province ko. Hindi siya combo filter eh but since Bosch, i want to try it again sa 4m40. Before sa 4d56 strada ko ay sulit siya kahit na every 7,500kms ako magpalit ng oil.
    #450
    mura yung 312 pesos. kasi 350 pesos bili ko 4d56 sa warren. made in korea yata.
    Yup, made in korea nga nakalagay. Doesn't look fake naman since distributor sila dto. May discount pa nga kasi cash kaya P299 lang bili ko. hehe
    Sayang walang pang-4m40 talaga plus hindi daw mabenta kaya hindi na sila nag-iimport. Tingin ko kulang lang sila sa push selling eh.
    Jun 2007
    #452
    I called civic merchandising, the retailer of fleetguard filters that dvldoc posted, sad to say most of what they have in stock are more of the industrial filters mainly heavy equipment, generators and the likes. but I have yet to received a call from them, the guy said he will check the principal inventory if they have the part number I'm looking for...
    Dec 2007
    #453
    Hopefully they got the filter your looking for. Those Titan Golds are a good option as well.
    I got about 3 responses back from Cummins filtration and they are doing a investigation into PACER, so hopefully it will clear out all the fakes shorty and people can actually buy there with confidence. That or they just loose there vendorship if they don't comply.
    Still hoping for a pic of a Purolator pic from ACE hardware, need the stamp on the top of the filter and the filter number.
    #454
    dvldoc, will try to drop by Ace to take some pictures (although they do not allow taking pictures inside the store) hehe
    Just be quick about it BG, I got a picture nung 360 view as posted above but not the top with the printout. Sayang nga.
    sorry double post
    Apr 2010
    #457
    Dec 2007
    #458
    Quote Originally Posted by doo View Post
    You are the man.
    #459
    dvldoc, RT,
    got this picture at the DIY store in greenhills.
    Dec 2007
    #460
    Great work man, do you have the filter number to? The production manager needs both.
Remote bypass oil filtration
