Thats alot of filters you got there!!
I have plenty for the crosswind, and the lf3564 are on the way. You can look at my adds on sulit or justt send a pm to keep the thread on topic.
I hope we do not flood this thread by posting "pm sent"
thats a lot of filters doc! haha! LF3830 and BD7028 doc....please advice...![]()
Currently using this Valvoline Blue 15w/40 that I ordered from a shop here in Baguio. Paid 3,300 for the pail containing 18 liters which is good for two change oils on my 4M41 Strada. Is this Valvoline Blue oil better than Delo 400? Delo is readily available compared to the Valvoline Blue that took one month to arrive after placing the order. Valvoline Blue is cheaper than the Delo 400.
They are about the same the only thing that matters is they both carry the Cummings rating
They both carry the same ratings so the will be for extended oil change intervals, the big C on the bottle is a winner everytime. Ace sells this for 199p a liter.
Based on specs alone, DELO 400 is looking better.Originally Posted by Ry_Tower
VALVOLINE ALL FLEET PREMIUM
Performance levels / Approvals
API CI-4/SL
ACEA 04- E2/B3/A2
ACEA 02- E2
MB 228.1/ MB228.3 / MB 229.1
Mack EO-M Premium Plus
Volvo VDS 3
Caterpillar ECF-1
ZF TE-ML 07C/04C, Allison C4
MAN 271
Cummins CES 20071/ 20076 / 20078
Typical Characteristics
Appearance Bright & Clear
SAE Grade 15W40
Kinematic Viscosity, cSt * 100oC 14.91
Viscosity Index 135
TBN, mg KOH/g 9.5
Flash Point, COC, oC 210
Pour Point, oC, Max. -30
CCS * -20 oC, cP, Max. 6700
http://www.valvolineasia.com/Upload/...et_Premium.pdf
Delo 400 Multigrade
PERFORMANCE CHARACTERISTICS
• API Cl-4 PLUS, Cl-4, CH-4
• API SL, SJ
• ACEA E7-08, E5-02, E3-96.
• JASO DH-1
• EMA Global DHD-1
• Caterpillar ECF-2, ECF-1-a
• Cummins CES 20078, 20077
• DDC 93K214
• Mack EO-N Premium Plus 03
• Mercedes-Benz 228.3
• Volvo VDS-3
Planned Approvals
• MAN M 3275
• ZF TE-ML 04C, 07C
• MTU Category 1 and 2
• Renault RLD-2
Meets the Requirements of
• API CG-4, CF-4, CF, CD
• Cummins CES 20076, 20072
• Mack EO-M Plus, EO-M
KEY PROPERTIES
SAE Grade: 15W-40
Density at 15°C, kg/L - 0.886
Base No., D2896, mg KOH/g - 12.2
Base No., D4739, mg KOH/g - 10.0
Sulfated Ash, %m - 1.4
Flash Point °C - 230
Pour Point °C (-33)
Viscosity, cSt at 40°C - 125
Viscosity, cst at 100°C - 15.1
Viscosity Index - 125
Zinc, %m - 0.15
http://www.caltex.com.au/productsand...n.aspx?ID=1639
