Page 97 of 330 FirstFirst ... 478793949596979899100101107147197 ... LastLast
Results 1,921 to 1,940 of 6586
    Oct 2011
    #1921
    I have also been using mobil delvac mx but il try the top 1 sdo in my next oci. CI-4 na rin un and im looking for at least 7-10k change oil. Sinusunod ko pa rin ung every 5k using mobil delvac mx.
    Sent from my iPad using Tsikot Car Forums
    Aug 2013
    #1922
    How much ang Top1 SDO? Used the 20w50 before, I felt na hirap ang engine, masyado thick even with our warm weather, konti baba ng temp, parang honey na siya.
    Meron ba available na 5w40 mineral motor oil sa local sources? Pwede na din sana yun TFSMO, wala lang ako makita PDS. Dahil sa natuto na read ng motor oil PDS, hirap tuloy decide what to use without knowing what's in it. hahaha!
    Sent from my Light using Tsikot Forums Mobile App mobile app
    #1923
    Top1 SDO 15w40 nasa 270-310/quart. Depende kung saan ka bibili.
    Oct 2011
    #1924
    Quote Originally Posted by johnjoseph View Post
    Pag 5W-40 mostly synthetic na yan sir. Wala akong alam na mineral na ganyan ang oil viscosity.
    #1925
    Sir ano ung oil na frkm caltex na maganda? Papachange oil ko vios ng inlaws ko sa suking servitek eh balak ko lagyan ng magandang oil po.
    Sent from my GT-I9505 using Tsikot Forums Mobile App mobile app
    #1926
    Top1 SDO is also SL rated pala. Sent an email to their HQ and it was confirmed by their tech.
    Oct 2011
    #1927
    Quote Originally Posted by brainmafia_310 View Post
    ung DGU na lang gamitin mo sir or kung kaya ng budget und Delo 400.
    Aug 2013
    #1928
    I think Delo 400 have a lower zinc content kaya lowered ang wear protection. It is CI-4+ for vehicles with EGR Euro 2 emission control standard, much better ang DGU, mas mura pa,okey din sa catalytic converter ng car engine.6
    Oct 2011
    #1929
    Hindi ba 1200ppm din ang delo 400 sir?
    Aug 2013
    #1930
    800 ppm na lang yata ang zinc ng CI-4+ Delo 400, mas lower pa di ang CJ-4 Delo 400 LE, Euro 4 compliant para sa ULSD fuel vehhicles with DPF. Hindi na maganda para sa old gas engines, less wear protection.
    Oct 2011
    #1931
    Noted sir. I thought Delo 400 would be much better with the "+" rating for extended oil change interval.
    1480ppm ang zinc nang delo 400. Sa viscosity index siya mababa vs dgu kaya much better for gas engines talaga dgu inho.
    Sent from my Lenovo using Tapatalk 2
    Aug 2013
    #1933
    Di ba pag API CI-4+/SM, CJ-4/SN, puro environment friendly na, low SAPPS at ZDDP? DGU have less than 1200 ppm zinc content, how come na maging 1480 ppm ang zinc ng Delo 400? CMIIW, zinc ang binabawasan para hindi masira in the long run ang cat con, egr, dpf and other ecs ng new model engines.
    May 2010
    #1934
    Guys, pa-advise ng magandang oil for lancer mx 2004.. Give me some choices, to check if available kay suking auto shop. The cheaper the better... Ako kase magbabayad for my sister.. Hehhehe.. Thank you! ;)
    Posted via Tsikot Mobile App
    Aug 2013
    #1935
    [QUOTE=romeocharlie;2289634]Guys, pa-advise ng magandang oil for lancer mx 2004.. Give me some choices, to check if available kay suking auto shop. The cheaper the better... Ako kase magbabayad for my sister.. Hehhehe.. Thank you! ;)
    Cmiiw, meron na cat con ang car mo. Try mo Caltex DGU or Mobil Delvac MX, both SAE 15w40, priced around Php230/liter, Korean oils Zic Up or Zic A, both SAE 10w40 priced around Php185/liter, all are cat con friendly and with high wear protection additives.
    Aug 2010
    #1936
    what can you say about this oil:
    delo 400
    petron revx all terrain
    royal purple 15w40
    for diesel engine po
    Oct 2011
    #1937
    Delo 400 - CI-4+ good oil for extended OCI.
    Petron RevX - no data sheet
    RP - good synthetic oil.
    May 2010
    #1938
    I thinking of using Petron RevX Trekker on all my old model gas fed cars.
    I used it in my scooter and my bros car which is an Altis G, ok naman.
    May 2010
    #1939
    diba CH4 lang ang delo?
    Aug 2011
    #1940
    Quote Originally Posted by SiRbossR View Post
    delo gold CH4.
    delo 400 CI4+
    delo gold ultra CI4.
    Sent from my ALCATEL ONE TOUCH 5020E using Tapatalk
Mineral , semi synthetic or fully synthetic?
