Page 95 of 200 FirstFirst ... 4585919293949596979899105145195 ... LastLast
Results 1,881 to 1,900 of 6586
    Apr 2012
    Okay ba yung Mobil1 5w40 TDT? Magkano per litre nun?
    I would put it in rotella t6 and delo 400 league. hdeo fully synthetic oils.
    540/liter at olx.
    Apr 2012
    540/liter at olx.
    Wanted to try Delo400 pero i read sa spec sheet niya na di pwede sa may DPF. My unit has DPF dahil grey market kaya yung Mobile TDT talaga hanap ko na ang mahal sa Ace hardware
    Apr 2012
    there is delo400 le (low emissions)
    which engine do you have? what does your owners manual require for engine oil?
    Apr 2012
    May Grand Starex is equipped with Euro V engine may DPF equipped siya. Wala naman specific na sinabi ang manual regarding sa oil. Pero nabasa ko kasi dati na di suitable sa DPF equipped and Delo400 not sure kung lumang spec sheet niya yun or pang ibang bansa.
    ayan shell rimula r4x dpf compatible. 200 plus lng ata
    petron revx all terrain dpf compatible din. medyo mahal ito. hehehe
    Apr 2012
    Hehe okay yan try ko r4x sa sunod na change oil which is 1k kms away.
    Na try ko na rin Delvac MX noon, lumakas consumo.
    Anyone here have experience with Mitasu oils? Binebenta sa True Value
    delvac mx is for serious heavy duty application. its not intended for passenger vehicles.
    i think its the same for Rimula R4x. it was designed to be used for trucks and mining equipments.
    Basta may dpf, u need acea c3 na oil
    I double checked. shell rimula r4x di pala pwede with dpf. mali ata basa ko sa pds nya.
    other choice is liquimoly diesel hi tech 5w40.
    there is a rimula r4 L for cars with dpf.
    Shell Rimula R4 L - Philippines
    http://www.shell.com.ph/products-services/on-the-road/consumer-lubricants-tpkg/trucks/shell-range-truck-heavy-duty-engine-oils/low-emission-multi-grade-oils/rimula-r4-l.html
    available pala sa pinas. good find
    Apr 2012
    Thanks for the replies
    Jun 2014
    Guys, due na ko for change oil. Which is better? Zic a+ 5w-30 or shell helix ultra with pure plus tech 0w-40 (both fully synthetic). For vios. Thanks
    Quote Originally Posted by _incubus19 View Post
    Try mo na lang pareho especially if same price. But choose the cheaper one if I were you.
    afaik, cheaper ang zic a+, pero as per experience, mas gusto ng 1.3 vios namin yung 5w40 helix ultra with pure plus compared to 10w40 na zic a (semi-syn).
    Shell Helix HX7 Diesel with pureplus 10w40 ba magkano? Have you checked their price? Wala pa sa supplier namin eh.
Mineral , semi synthetic or fully synthetic?
