Results 1,481 to 1,490 of 6542
July 9th, 2013 07:32 PM #1481
July 10th, 2013 02:32 PM #1482
MOTOR OIL “WEAR PROTECTION” RANKING LIST 540RAT - Tech Facts, NOT Myths
Top 10
1. 5W30 Pennzoil Ultra, API SM synthetic = 115,612 psi
I have not been able to find this oil with the latest API SN certification. The bottle says, “No leading synthetic oil provides better wear protection”. For once, a product’s hype turns out to be true. And this oil provides MORE THAN TWICE as much wear protection as the lowest ranked oil on this list.
zinc = 806 ppm
phosphorus = 812 ppm
moly = 66 ppm
calcium = 3,011 ppm
TBN = 10.3
2. 5W30 Oil Extreme, API SM conventional = 110,286 psi
The Company claims this oil contains their proprietary formula of calcium petroleum sulfontate EP (Extreme Pressure) technology that is NOT found in any other motor oil. They also claim that it will provide 5 to 7 more HP, 7 to 10% better fuel mileage, cut engine wear in half, and will extend drain intervals two or three times safely. This oil is endorsed and promoted by Tech Author David Vizard. And he was so impressed by this oil’s performance that he also became a share holder in the Company. The “Dynamic Wear Testing Under Load” performed here, supports their claim regarding wear protection. This product’s hype about that, turns out to be true.
zinc = 765 ppm
phosphorus = 624 ppm
moly = 52 ppm
calcium = 7,652 ppm
TBN = 23.2
3. 10W30 Lucas Racing Only synthetic = 106,505 psi
zinc = 2642 ppm
phosphorus = 3489 ppm
moly = 1764 ppm
calcium = 2,929 ppm
TBN = 9.0
NOTE: This oil is suitable for short term racing use only, and is not suitable for street use.
4. 5W30 Mobil 1, API SN synthetic = 105,875 psi
zinc = 801 ppm
phosphorus = 842 ppm
moly = 112 ppm
calcium = 799 ppm
TBN = 7.5
5. 0W30 Amsoil Signature Series 25,000 miles, API SN synthetic = 105,008 psi
zinc = 824 ppm
phosphorus = 960 ppm
moly = 161 ppm
calcium = 3,354 ppm
TBN = 11.4
6. 10W30 Valvoline NSL (Not Street Legal) Conventional Racing Oil = 103,846 psi
zinc = 1669 ppm
phosphorus = 1518 ppm
moly = 784 ppm
calcium = 1,607 ppm
TBN = 4.4
7. 5W50 Motorcraft, API SN synthetic = 103,517 psi
zinc = 606 ppm
phosphorus = 742 ppm
moly = 28 ppm
calcium = 1,710 ppm
TBN = 6.7
8. 10W30 Valvoline VR1 Conventional Racing Oil (silver bottle) = 103,505 psi
zinc = 1472 ppm
phosphorus = 1544 ppm
moly = 3 ppm
calcium = 2,707 ppm
TBN = 7.6
9. 10W30 Valvoline VR1 Synthetic Racing Oil, API SL (black bottle) = 101,139 psi
zinc = 1180 ppm
phosphorus = 1112 ppm
moly = 162 ppm
calcium = 2,664 ppm
TBN = 7.4
10. 5W30 Pennzoil, API SN conventional, yellow bottle, with Oil Extreme concentrate added in = 100,252 psi
This oil on its own WITHOUT the “Oil Extreme concentrate” added to it, has a wear protection capability of only 76,989 psi, and is ranked 53rd. But, with the concentrate added, its wear protection capability “WENT UP A WHOPPING 30.2%”. This is the first additive I’ve ever tested that actually worked as advertised.
zinc = 970 ppm
phosphorus = 749 ppm, this value is 91 ppm lower than the basic oil because the concentrate has less phosphorus in it, which dilutes the overall ppm count of the mixture.
moly = 285 ppm
calcium = 4,443 ppm
TBN = 18.8
540 RAT
Member SAE (Society of Automotive Engineers)
- Apr 2010
- 97
July 11th, 2013 07:54 PM #1483salamat mga bossing, ipon mode muna ako sa ngayon. saka ko pa check uli sa shop kung ok na budget. thanks
Tsikot Member Rank 5
- Nov 2003
- 3,849
July 14th, 2013 12:29 AM #1488
Group IV - PAO Based
Group V - Catch-all group (POE, PAG, PFPAE, etc.) Anything that is not G1-G4.
Amsoil (Except OE, XL, Break-in)
Castrol (German made)
Liqui Moly (Lubro Moly)
Mobil 1 0w40
Mobil 1 5W50
Motul (Specific, H-Tech, 6100, 8100, 300v)
Redline (All)
Royal Purple (Except break-in)
Torco (Except TD-1 and break-in)
This is the list of Group 4 and Group 5 based synthetics that I know of. Feel free to edit pag may mali or may ma-add kayo sa list.
- Nov 2003
- 3,849
July 15th, 2013 11:39 AM #1489that list looks about right but i'm not sure about Castrol and mobil. i'm pretty sure group III lang sila but I could be wrong.
July 15th, 2013 11:50 AM #1490
Castrol edge and mobil 1? Those are expensive FS oil, kung Group 3 lang not worth it.
Testing Toyota's Failing Hydrogen Car Donut
Another Toyota first: Mirai
