Page 139 of 200 FirstFirst ... 3989129135136137138139140141142143149189 ... LastLast
Results 2,761 to 2,780 of 6586
    Salamat sirs StockEngine and crazy_boy.
    Subukan ko lang yung X7 sa FD namin. May nakita ko shop dito sa Alabang na may Zic. Will give it a try. Sayang walang Baldwin filter dito di aabot kung papa ship.
    Quote Originally Posted by cjv_justice View Post
    There are different varieties of x7
    X7 for gas and diesel.
    X7 acea a3/b4 5w30 and 5w40 - for european spec or extra extended drain intervals
    X7 api-sn 5w30 rc - this would be good for your fd with matching improved fc.
    Not sure which ones are not available locally.
    Jan 2016
    Kung sa motortown yan sir, pa share na lang what store name, and the type and price of zic oil you bought. Thanks.
    Oct 2014
    FYI : ZIC dealer in FB post.
    T-Parts Zic Oil Distributor | Facebook
    Aug 2012
    Guys, I saw this Lexus motor oil in a retail store. Can this be used for Mitsubishi car? It meets the requirement of my car which is API SM 5W-40. What do you think?
    Sent from my D5833 using Tapatalk
    Apr 2012
    Quote Originally Posted by red_one View Post
    Yes most likely repacked din yan
    Sent from my LG-H818 using Tapatalk
    Yes, confirmed na repacked Mobil ang Toyota oils. Yan ginagamit mismo sa planta nila sa yokohama afaik. So most probably yan din sa ibang plants nila.
    Oil is made by snloc, this is a dubai/uae company. I dont think it meet other specs only Api-sm = mid tbn
    If the price is right then go for it.
    Also if youre going to use this on a mivec mirage, better to use xw30 or xw20.
    Aug 2012
    Car is Mitsubishi ASX 2.0L 4B11 MIVEC.
    Do you happen to know the viscosity of Mitsubishi Turbo XP Full Synthetic Oil? Yun kasi nilagay ng casa last oil change.
    I think they have 2 turbo xp fully synthetic oils a 5w40 and 5w30.
    The monteros use 5w30 fs turbo xp for diesel.
    Your 2.0 mivec can take 5w40 and it does ask for api sm. If the Lexus 4L bottle is less than 1300pesos go for it.
    I would just use a zic x7 5w30 api-sn oil. Its cheaper and you will have better fc. I would reckon zic will have a better additive package than that lexus oil lol.
    Aug 2012
    An OLX seller actually quoted me:
    Zic XQ 5W-40 = P2200 for 4L bottle.
    Zic X7 5W-30 = P1850 for 4L bottle.
    Zic X7 10W-40 = P850 for 4L bottle.
    He said Full Synthetic din daw ang X7 10W-40. Is this correct?
    Oct 2009
    Meron na ba nakasubok dito ng Shell Helix Ultra 5W-40 sa gas engines? How's the performance of this oil? At anong group pala eto? 4 or 5? Thanks!
    Meron na nakagamit sa inyo yun engine oil na binebenta sa true value? Japanese brand eh.
    Mitasu? Si baludoy alam ko gumagamit nun.
    Yan nga! Maganda kaya? Everytime pumupunta ako true value laging ko check yan. [emoji23] hinde naman bumibili
    Gumamit ako once ng 5w-30 ng mitasu pero bumalik din ako sa mag 1 of the same viscosity kasi for some reason tumaas konsumo ko pero generally pareho lang naman rota ko.
    Sent from my ASUS_Z00AD using Tsikot Forums mobile app
    Aug 2012
    Whereas sa Zic X9, ang nakalagay sa Description ay "ZIC X9 5W-40 is a fully synthetic motor oil..."
    Aug 2005
    I have switched to zic x7 10w30 from mobil 1 tdt as far as I've gathered, maraming nang fake sa mobil 1 tdt.
    Sent from Zenfone2
    any feedback for this oil?
    Sent from my SM-A9100 using Tapatalk
Mineral , semi synthetic or fully synthetic?
