Page 153 of 330 FirstFirst ... 53103143149150151152153154155156157163203253 ... LastLast
Results 3,041 to 3,060 of 6586
    Jan 2012
    #3041
    Thanks sa advise sir, tawagan ko na lang yung casa para tanungin kung anong viscousity ng oil yung ginagamit nila para sa swift, katatapos rin lang kasi nung warrant ng sasakyan kaya nagdecide na ako na sa labas na lang magpachange oil, medyo masaket kasi sa bulsa kapag susundin pa namen yung every 3 months/5k, nung last na punta namen dun 8k rin ang binayad namen hehe. 3 yrs na yung auto at nasa 13,xxx kms pa lang natatakbo.
    Apr 2014
    #3042
    Guys don't over complicate oil changes.
    Step 1: Check the manual if your engine require SN, SM, CF, CI-4, CJ-4 etc., certified oil.
    Step 2: Check the temperate chart as well. It represents the ambient temperatures where you'll operate the vehicle. In the Philippines it can range from 10c (Baguio) to 38c, average around 30c.
    Step 3: Check your budget. If you can afford synthetic go for it! Its the best oil you can buy. If on a budget consider semi-syn or plain mineral oil.
    Step 4: Choosing the viscosity grade of the oil. (0w-30, 5w-30, 5w-40, 10w-40, 20w-40, etc.) Focus on the second number since we do not have snow here. The first number e.g. (5w) represents the oil viscosity during winter. That simply means you can use whatever multi-grade oil available for your engine.
    Whatever oil you use does not matter much, what matters is you change your oil. Your budget will determine if you'll be using synthetic, semi or mineral.
    #3043
    Fully Synthetic for me since my car only runs about 5k kms per year. Casa requires shorter period (3 mos) if I use regular oil.
    Aug 2012
    #3044
    #3045
    Quote Originally Posted by red_one View Post
    Thanks for this. I never knew a turbo charged engine is considered severe usage. Though there are so many opinions with regards to O/C intervals, with one even saying that the traditional O/C interval of 7,500 for semi syn is 19-kopong kopong pa, I feel that we should just trust the manufacturer's recommendation. The oil viscosity may not change much with the newer generation oil, but breakdown of additives & dirt saturation of the oil may warrant the recommended O/C interval. This is debatable for some, but to each his own.
    Mar 2005
    #3046
    From what manual ito bro?
    Aug 2012
    #3047
    Quote Originally Posted by jasonub View Post
    compiled from everybody's manual including Toyota, Honda, Ford, online forums and current articles about today's oils.
    Yung sa diesel masyado naman yang maiksi. Diesel sa akin at parehong turbochrged pero kahit mineral oil, 5,000kms or 6 months OCI lang puwede na. Never had any problems sa engine. Basta API CH and up lang gamit ko kasi yun bagay sa turbo diesel. Preferably API CI rated oil.
    Maganda na mga langis ngayon.
    Aug 2012
    #3049
    That's already covered. Meron naman note sa baba.
    *Oil change interval may be extended based on oil analysis but must not exceed 1 year.
    Mar 2005
    #3050
    thanks for the heads up
    Mar 2005
    #3051
    Oct 2009
    #3052
    Semi ako then every 5k
    Oct 2009
    #3053
    Nice share.
    Dec 2014
    #3054
    Is it true na hindi recommended ang fully synthetic oil sa new engine?
    #3055
    Quote Originally Posted by Gel999 View Post
    Who told you that? As far as I know, from reading this thread & other articles, fully synthetics are far more superior in protecting a new engine than mineral based oils & are more stable under varied temp. ranges (i.e heavy traffic conditions). It does not mean that you can't use minerals, you just have to use the right grade & API rating as recommended by the manufacturer.
    It wasnt recommended before because car dealers wanted to squeeze more money from customers.
    #3057
    If you are just breaking-in the motor or for short OCI say 5k kms, its a waste of money going fully synthetic.
    Newer oils based on dino or hydrocracked nowadays offers good additives comparable to esther or PAO based synthetics.
    Its true that Fully Synthetics last longer, but who wants to change oil every 1 year on a new motor when the oil is already pit black and you are trying to convince yourself the oil is still good without any oil analysis to back it up?
    #3058
    Sakin kung ramdam na mahina na humatak yung engine, kahit wala pa sa specified kilometers na natatakbo, pinapalitan ko na yung oil.
    BTW, has anyone tried using Bardahl SynPower Fully Synthetic 15W-40? I'm planning to use this on D4D engine. Sa area lang namin ako naghahanap eh so kokonti lang mapapagpilian. Meron din nga palang Top 1 SDO, but currently looking for FS oils. TIA
    #3059
    Apr 2012
    #3060
    Quote Originally Posted by andrewnathaniel View Post
    Okay yang TOP1 SDO.
Mineral , semi synthetic or fully synthetic?
