natatawa rin ako eh.. 🤣🤣🤣
bro cb nagtatanong ka ano mileage ng mga tsikot ng buyers?
*cb
Bro how about Isuzu Elf trucks with 4hf1/4hg1 engines? Nakalagay kasi sa manual do not use synthetic. Is that BS or may reason ba talaga why dino oil lang pwede.
^same with local Nissan Patrol Safari GU series. May sticker din na do not use synthetic. I would presume the manufacturers do want want the owners to do extended OCI or wrong viscosity oil. Synthetic has more additives compared to dino oil. I dont see anything wrong using synthetic as long as you follow the API requirement and viscosity.
ps, im no oil expert![]()
petron is now on lazada... but their price range is not worth talking about 🤣
Petron - Buy Petron at Best Price in the Philippines | www.lazada.com.ph
Nasa 2.5k na tinakbo d4d engine ko using mobil mx. Pansin ko mas smooth at nabawasan vibration konti engine so far satisfied ako sa mx sa response and sa pino ng engine. Ang ayaw ko lang parang lumakas ako sa consumo sa diesel.
Sent from my SM-J500G using Tsikot Forums mobile app
Viscosity range for a 40w is 12.5-16.3. The higher it is, the less vibration. If the oil is for diesel engines only ie HDEO it is at least 14 and goes all the way to 16.3.
The delvax mx xw40 is probably on the heavy side...
Kagandahan sa mx smooth parin kahit 2k kms plus na tinakbo. May mga na try na ako sa umpisa lang smooth after 1k kms magaspang na ulit hehe
Any bad effect if I will switch to FS oil, coming from mineral oil since 0KMs, on my next PMS which is at 40k KMs?
if you try the pertua additive. it will thicken up your oil. and you will feel less vibrations 😉
With engine oil ... 30 is the new 40 ... there are several articles about this online ...
none for a not so abuse 40k old engine. you can check naman if there is an oil leak because of bad seals or gaskets. 40k and 4yr old?
Any feedback re this brand of OIL
VIDEO here
https://web.facebook.com/HyundaiXTee...0486923673680/
zicph.com is the official website of zic Philippines
not sure why some variants of x7 are not there though
