Page 15 of 330 FirstFirst ... 51112131415161718192565115 ... LastLast
Results 281 to 300 of 6586
    Oct 2011
    #281
    Quote Originally Posted by miko101130 View Post
    Sir, madame FS oil na CJ-4,CI-4,SL rated....
    pag ang oil kasi ay CI-4 only, usually semi synthetic lang....
    Mostly the FS oil ay either Cj-4 or SN specs na.... updated na kasi ang APi rating nila...
    cge sir, verify ko ulit and check ko rin ung label sa ibang brands of FS oil. thanks sir.
    Sir thanks for the reply. I guess di ko na ttry to hehe risky pala masyado. Last change oil ko was mid January pa and since then 3k+ kms pa lang tinakbo ng oto, 2-3x a week lang kasi nagagamit since wala pa akong pasok. Ok lang ba na sagarin kong 10k or mas maigi mag change oil na before the year ends (in the -ber months)? I used Idemitsu FS oil from Unioil 5w30 on my last oil change.
    FS oils can be used for more than a year. Follow the 10k kms schedule.
    #283
    kaso naka Toyota engine siya. Vios if im not mistaken. sa toyota namin (innova and vios, both gas), 5k km oil change parin ako. with Baldwin filter and Zic oil. mahirap na since prone to sludge yung engine.
    #284
    sa uni oil naka price rollback ang oil P1,3++.++ na lang ang idemitsu extreme eco
    May 2005
    #285
    ZIC A ba gamit mo? AFAIK, ZIC is semi synthetic so you are right with the 5k OCI on your vehicles.
    About the Toyota engine sludge, are the 1NZ-FE in the Vios and 1TR-FE in the Innova affected? Locally, I have read about sludge issues with local Altis with 3ZZFE engines. In the US, Camry had sludge problems.
    #286
    vios meron din may sludges.
    as for the semi-synthetic na 5k OCI, i think it would really depend on the additives of the oil. not only based on the type of oil.
    Oct 2011
    #287
    Sir, affected din ba ang 2kd-ftv sa toyota engine sludges?
    May 2005
    #288
    ^How's the ZIC A? Can it last for a year bet. OCI if I don't cover 5k kms in a year?
    #289
    im using Zic A. its better than the same priced OEM toyota mineral oil.
    with the price i paid for it, im happy with the performance.
    as for the OCI, i cant really give you a concrete answer since i do not have a data to back it up. but i will use it for a year or 5k km whichever comes first.
    Guess he better use Delo Gold Ultra or Top 1 SDO then. Better cleansing agents, just enough zinc at 1200ppm. That can cure the sludge problem.
    #291
    good oil + good filter will prevent sludge im just being on the safe side thats why i still change oil at 5k km interval. the Baldwin filter and Zic A oil is not too expensive naman. almost same price with other mineral oil and replacement filters hehe
    OT: RT, papa-order ka pa ba nung 7095?
    Wait ko muna yung reply ng insan ko sa US. Baka kasi may makita siya na mura sa kanila. If wala kasi, plan ko is oil anf uel filters na bosch na ulit so isang ordern lang. parang sayang freight if 1 pc lang eh. hehe
    #293
    Wala pa naman sludge hehe pero may nakita kasi akong Vios na may sludge so nag-aalala rin ako. 2NZ-FE (1.3 engine) yung akin. Dec 07 acquired yung car pero 33k pa lang tinatakbo and since then kada 10k kms ang interval ng change oil ng FS. FS sya since day 1. Medyo napaparanoid lang ako kaya I'm considering those "cleaning" oils for my next oil change. Btw ok lang ba oem Toyota oil filter? TIA again. Laking tulong po ng replies nyo.
  14. #294
    mobil1 semi-syn + fram extraguard oil filter for my old mazda truck. will try idemitsu extreme eco FS + fram toughguard on my next oil change [3000km or 5months whichever comes first].
    for my ol reliable vw type1, oil change is 4x a year regardless of mileage. 2.5L lang kasi ang oil cap nito. hehe. regular dino oil only. will try FS and will see diff in performance.
    May 2005
    #295
    Got to watch out first for the kind of diesel oils being used on gasoline engines w/ catalytic converter.
    Jan 2008
    #296
    My vios acquired year 2007 (1.5lit) never pa nakatikim ng FS oil, semi synthetic lang, no problem sa sludge. Religiously maintained every 5k kms.
    Currently using Zic A. Before e Toyota Motor oil, shell semi synth mobil mineral oil.
    Kaya nga dapat less than 1200ppm yung zinc, yun ata kalaban ng cat con eh.
    #298
    Quote Originally Posted by Errol5 View Post
    It's the same case in my 2007 Altis. 80,000kms on hand and it's still running clean using mineral based 15W-40 oil and the POS VIC filters.
    I think i'll try the ZIC oils the next time around. Same price anyways.
    #299
    Some of the guys i know here use the 10k sched with FS oils, but the change the filters mid-year with 1 quart FS oil replenish.
    #300
    + Baldwin filters. its just 215pesos.
Mineral , semi synthetic or fully synthetic?
