Page 12 of 330 FirstFirst ... 289101112131415162262112 ... LastLast
Results 221 to 240 of 6586
    Why is it nakalagay sa manual ng Sonata namin, 5W30 ang recommended na viscosity kahit tropical climate? Di ba dapat 5W40?
    Baka yung design sir talaga ng engine eh ok na yung w30 viscosity kahit sa tropical climate. Ok lang yan IMO.
    Dec 2009
    #222
    newer gasoline engines are geared towards fuel efficiency and emission compliance...
    nauuso kasi mga tintatawag na "energy conserving oils" ( ILSAC GF-5 ) yan ang mga 0w-20 / 0w-30 / 5w-30/10w-30
    the more an oil is able to provide fuel efficiency the lesser it provides wear protection.... because of its thinning...
    the thinner the oil and easier to flow the better fuel economy but is not good at protecting the engines at high temp high load conditions...
    Jul 2006
    #223
    Pero it's stated in the manual. Why would Hyundai reccomend such viscosity if it means lesser wear protection for the engine.
    Oct 2011
    #224
    Sir, 5W-30 ung recommended pero nakalagay ba sa manual ung ibang oil viscosity grade na pwede rin?
    Jul 2006
    #225
    Yup nakalagay din. 10w30 yata yung isa, then 5w20 pero bawal daw sa sobrang init na climate like in the middle east. Wala akong nakita na 40 ang dulo
    Oct 2011
    #226
    sundin mo ang manual. baka masyadong thick na ung 40 para sa theta II engine.
    Jul 2011
    #227
    Quote Originally Posted by miko101130 View Post
    yes sir.. correct po kayo... Idemitsu japan is PAO based... maganda din oil nila... for gasolines
    so ibig sabihin OK lang i-extend ung oil change interval to 10Km/1yr (which ever comes first)?
    Dec 2009
    #228
    yes basta mga PAO based engine oil pwede yan sa extended drain interval provided "used good and quality filters".....
    Dec 2009
    #229
    basta sundin ang nasa manual pag ang vehicle ay under warranty para walang issue if ever magka-warranty claims in the future pero kung out of warranty na, 10w40 is a unviversal weight for tropical climates like here... changing from 10w30 to 10w40 doesn't really have any adverse effect unless the engine system is different from traditional engine builds...
    Oct 2011
    #230
    may nabasa akong article na sinasabi pag bago ang engine much better ang 30 viscosity. pero pag gamit na pwede na 40. hindi ko lang alam kung ano ang logic dito.
    Nov 2003
    #231
    most synthetics should be able to sustain a 10k km oil change interval.
    stick with the required viscosity for the engine whether it's new or old na. you can change viscosities if you mod it or there are other factors, but in most cases, stick with the manufacturers recommended viscosity.
    Oct 2011
    #232
    OT:
    I would like to ask regarding engine noise especially for diesel engine. Why is it that during a cold start, engine seems to be quiet. But after some driving, you could hear the engine noise and then it would revert back to being quiet. Is this the norm for a diesel engine? can it be quiet all through out if you use a FS oil?
    Nov 2003
    #233
    doesn't seem normal to me. engine sound should be the same regardless of temp or time running.
    the sound may decrease slightly with better oil but if there is a sound, this may be indicative of other problems the engine may have.
    Oct 2011
    #234
    Sir, the sound that im referring to is the usual diesel engine sound. it is just that at times it becomes slightly louder than usual but would always revert back to quiet sound. Nothing unusual like knocking sound or something. Good point on your comment that engine sound must be the same regardless of temp and time running. I'll see when I change it with a good oil.
    Oct 2011
    #235
    Just to clarify. We often hear the phrase "for extended oil change interval". Does this applies to all CI-4 rated diesel engine oil? or which API rating does the phrase refer to?
    May 2009
    #236
    OT:
    baliktad ang scenario mo ah. sa pipip ko, maingay when cold for about 5 seconds then going silent na when the oil have fully circulated. at mas silent pa when hot na.
    have it checked to be sure. ano ba yan? conventional or crdi diesel?
    Oct 2004
    #237
    Baka ang radiator fan lang yung maingay. Mas frequent ata to naka-on pag normal engine temp na keysa cold engine temp.
    Oct 2011
    #238
    Quote Originally Posted by miked View Post
    Sir, CRDi diesel. cge, pakinggan ko mabuti kung sa engine or pwede rin sa radiator fan as sir doy stated. Usually when I'm in full stop at traffic light, I would at times turn-off the radio and hear the engine sound, sometimes it is medyo loud (but not unusually loud) but sometimes tahimik naman. I noticed also when I'm at full stop and shift the gear to neutral tumatahimik ung engine sound.
    May 2005
    #239
    Any comments on the Mobil 1 (0W-40)? Php 610/liter. American Stock (silver packaging) and not Asia market (bronze package)
    Mobil 1 0W-40 Advanced Full Synthetic Motor Oil
    Definitely a Group IV oil.
    Dec 2009
    #240
    that oil is very good... factory fill for high end cars brands.... you can't go wrong with that...
    API SN/SM/SL/SJ
    Viscosity Index 185
    Total Base Number (ASTM D2896) 11.8
    HTHS Viscosity, mPa•s * 150ºC, (ASTM D4683) 3.8
Mineral , semi synthetic or fully synthetic?
