Results 91 to 100 of 6542
May 3rd, 2012 07:35 AM #91
hi!
i've been using the regular 20w-50 oil on my '78 beetle. i've tried petron ultron & the shell helix brand. oil change is every 2-3months regardless of the number of kilometers. it only consumes 2.5L [and no oil filter change!] some guys said that the caltex delo multigrade diesel engine oil is the better choice for the aircooled bug because it's thicker and would protect the engine internals more than the regular gasoline motor oils can. is this true? would it also be better if i use semi-syn like the valvoline durablend or shell helix blue or mobil1? how about idemitsu eco, top1 and repsol?
thanks!
May 3rd, 2012 07:44 AM #92
how about the 4G50series mitsu gas engines? is it okay to use synthetic 5w-40, 5w-30, 10w-40? or stick with the mineral 20w-50 and change every 5 months / 5000km [whichever comes first]?
i've been using the semi-syn mobil1 10w-40 + FRAM oil filter every 5months or 3000km [whichever comes first]. overkill?
i also want to try other oils i.e. royal purple, top1, repsol, and idemitsu. please share your thoughts and experiences on these oil brands! thanks!
May 3rd, 2012 12:25 PM #93
Okay, thank you for the info regarding diesel oil sir. I must admit, mostly sa sinabi ng mekaniko usually ang mga nalalaman ko sa technical ng kotse. Good thing, may mga expert tsikoters dito.
May 4th, 2012 09:34 AM #94
May 4th, 2012 11:35 AM #95
Yes sa ratio ng additive package kaya mas mahal HX7.
Shell Helix Diesel HX7 | PhilippinesFasten your seatbelt! Or else... Driven To Thrill!
May 4th, 2012 11:44 AM #96
mga chong, ayos lang ba ang shell helix diesel plus sa 10 year old diesel ride ko? parang nalalabnawan kasi ako. and since madaling mag sludge oil ko for having short trips only, is it ok if i just change oil as usual? without engine flush, o kailangan na talaga?
TIA sa mga sasagot!
May 4th, 2012 12:42 PM #97
Ano ba sir diesel ride mo. After reading so much I beleive depende din kasi sa ride mo yung ideal oil. Kung puro short trips, much better talaga na early yung palit mo at 5,000kms kesa extended tapos multigrade mineral oil na lang.
Hindi na ako bilib sa Shell Helix Diesel eh. Mas ok pa nga specs ng Shell Rimula R3 if you come to think of it.Fasten your seatbelt! Or else... Driven To Thrill!
May 4th, 2012 01:07 PM #98
May 4th, 2012 05:10 PM #99
Sa crosswind okay na yung shell rimula r3, caltex delo gold ultra, Mobil delvac mx or any cheap API CH-4 or CI-4 rated oil since 5,000kms ka mag-change oil.
No need for engine flush IMO. Hindi pa naman sobrang tagal ng oil eh.
Yung bumubulwak sa dipstick hindi maganda yan, may loose compression na ibig sabihin. Pa-check mo na sa reliable auto shop sir.Fasten your seatbelt! Or else... Driven To Thrill!
May 4th, 2012 07:03 PM #100
bro thanks! actually kagagaling ko lang sa shell for change oil. HX5 ang ginamit ko ngayon, parang tumahimik naman at gumaan ang takbo ng 4ja1 ko parang Helix diesel plus. pakiramdaman ko lang after some kms. btw, the mechanic strongly advised that i have my engine flushed since malapot na yung oil at may gunk na talaga. i was convinced then he used Shell Rimula R1 SAE-40. i dunno how effective this is but i saw what came out after making my engine gargle.
anyway thanks a lot bro Ry and have a nice day!
Xiaomi E-Car
