Page 9 of 330 FirstFirst ... 56789101112131959109 ... LastLast
Results 161 to 180 of 6586
    Dec 2009
    #161
    Quote Originally Posted by holdencaulfield View Post
    sige try ko nga delo gold next oil change. dungis kasi ng mga caltex stations dito, katamad din mag DIY.
    tumahimik 4ja1 ko sa HX5. sana ganito lang until the next hundred kms.
    tama ka diyan, madungis mga caltex stations, and mostly ang parokyano nila ay mga jeep and trucks na naka-park harap nila... tapos nagmumukang talyer yung gasoline stations...
    hindi naman lahat ganun, pero its a generalization that i think has some basis... hehehe...
    Dec 2009
    #162
    Quote Originally Posted by AC View Post
    guys.. pasuggest naman po ng suki supplier ng langis:D
    haha.... Sir AC, kita na lang tom hapon for your oil needs....
    May 2009
    #163
    Quote Originally Posted by miko101130 View Post
    haha....yung petron dito ang suki ng mga jeepney dahil mas mura petron oils....nilalangaw nga yung caltex eh.
    nga pala gusto ko rin subukan kung sakali yung fuchs lubricants. as per sa konting msds na nakita ko sa net mukhang ok. makikita pa rin kung papano..hinahanap ko lang yung location dito sa amin na sinabi ng officemate ko.
    Oct 2011
    #164
    FYI lang, Shell Rimula R3 X Php204/Li and Shell HX5 Php254/Li sa Shell station.
    ^ Shell Rimula R3 X ka na lang diba. Better rating and addtives pa.
    May 2009
    #166
    ^onga. mukhang primarily for gasoline engines din kasi ang HX5 as per API SL/CF rating nya.
    Sep 2009
    #167
    napansin ko suabe takbo ng 4ja1 ko sa hx5. parang ayos to ah. antay pako ng ilang linggo pa.
    May 2009
    #168
    maingay na uli pagkatapos. hehehe. jowk lang brader.
    just use oils primarily designed for diesels and you're good to go....syempre, kilatisin pa rin yung rating and additive package ika nga.
    Sep 2011
    #169
    Bakit mas ok ang 15w40 kaysa 10w30?
    Napapaisip kasi ako bumalik sa honda lev oil.
    Currently, 4 years na ako sa delo gold.
    Oct 2011
    #170
    Quote Originally Posted by tomboy View Post
    Oil thins when hot and thickens when it is cold. Since Philippine is in the tropical hot climate, most prefer using either 15W-40 or 10W-40 multigrade oil with higher viscosity rating especially at engine operating temperature.
    Oct 2011
    #171
    yep, much better additives ang Rimula R3 X but of course I will go for Delo Gold Ultra na lang as you suggested with a higher API rating and pricewise hindi naman mahal.
    Oct 2011
    #172
    Quote Originally Posted by Ginnova View Post
    how about gasoline engines ano naman ang maganda and affordable that is safe enough for 10k OCI.
    Up ko lang ito para sa mga oil gurus here.
    Jan 2008
    #173
    ^currently using Elf Excellium SM + baldwin oil filter on my gf's 08 Altis.
    here's a link of its specs and reviews:
    ELF EXCELLIUM SM 5W40 2010 - Singapore Motor Guide
    so far so good. at 550php /liter, mas mura to compared sa motul (640?), mobil1 (800+) at valvoline Synpower (700+/-).
    Delo Gold Ultra/Mobil delvac Mx or any diesel oil with API CI-4 and SL rating. Yan ang maganda for extended oil drain itervals eh. Again balikan yung manual ng ride mo if designated na API SM/SN dapat. Yun kasi yung kelangan if may catalytic converter ride mo eh. Bawal dun yung mataas zinc which is marami yung mga API SJ/SL oils most of the time. But if manual recommends SL rating, IMO the best pa din mga diesel oils even for gasoline engine. Nakalagay din naman sa bottle nila yun eh.
    Oct 2011
    #175
    okay thanks sir. this was brought up by sir ginnova and for the vvti engine, API SL or SM is recommended in the manual. So, I guess they could also use Delo Gold Ultra or Mobil Delvac MX for their gasoline powered engine.
    Dec 2009
    #176
    mas robust ang mga diesel rated engine oils at maganda kasi additives package....
    Oct 2011
    #177
    For modern CRDi engines specifically for those korean SUV's which is powered by R-eVGT engine, will the Delo Gold Ultra/Mobil Delvac MX or any API CI-4 rated diesel oil work on that type of engine? o kailangan talaga ung mga fully synthetic oil like Mobil 1 or RP. I have read in other threads na dapat synthetic oil ang gamitin with that particular type of engine. Kindly advised. Thanks.
    Dec 2009
    #178
    its not actually a question sir retz of whether its fully or semi synthetic or mineral... i think the advised made by HARI on insisting that user owners and casa must use FS oil, is base on the emission devices that came with their models , the Selective Catalytic reduction devices and their diesel particulate filters together with prolonging oxygen sensor...
    which needs low Phosphorus and zinc (SAPS)
    kung hindi kasi issue ang mga emission devices na toh... Delo Gold and Delvac and other strong diesel lubricants will offer much longer protection...
    kaso need nang casa na i-prioritize na ma-prolong life nang mga emission device,,
    most Fully synthetic oils are CJ-4 rated na.... meh limit na sa ZINC and Phosphorus...
    Jan 2008
    #179
    ^Mobil TDT pa lang yata nakita ko na Cj-4
    Apr 2011
    #180
    [QUOTE=Errol5;1926065]^Mobil TDT pa lang yata nakita ko na Cj-4[/QUOTE
    try mo tingnan sa ACEhardware yung MAG 1 All Fleet SAE 10w30 at saka SAE15w40 engine oil its rated as API CJ-4/SL,SJ.
    it cost around 1300+
Mineral , semi synthetic or fully synthetic?
