Page 8 of 330 FirstFirst ... 4567891011121858108 ... LastLast
Results 141 to 160 of 6586
    May 2009
    #141
    Mas mahal talaga yung Delo sa mismong Caltex station kaya kapag may bagong version is konti muna binibili ko sa station tapos aantayin ko magkakaroon yung suki ko na auto parts. kapag oils sa caltex ako, kapag diesel fuel sa petron (dahil sa advantage card) at sa shell para sa 2T (pansin ko mas smooth dito takbo eh). sorry a bit OT. hehe
    May 2009
    #142
    which is better, delo 400 or mobil mx?
    my money on 400....technically, mas lamang delo 400 kung titignan mo pds/msds nilang dalawa. multi-oil test rated pa ang 400 kesa mx
    Oct 2011
    #143
    Ung Delo 400 synthetic ba ito kaya mas mahal kumpara sa Delo Gold and Delo Gold Ultra? And ung API rating ng Delo Gold and Delo Gold Ultra mukhang parehas lang. Additives lang ba ang pagkakaiba?
    ^ Delo Gold is APi CH-4 only, Ultra yung CI-4. Mas mataas additive package ng Delo Gold Ultra.
    Quote Originally Posted by miked View Post
    I have to agree, may halong group III sa chem composition niya eh pero Delo Ultra and Mobil Delvac MX is group II. But if hindi naman lalampas sa 10,000kms COI na plan mo, kahit saan dyan ang piliin, and do get the one that is cheaper and readily available sa'yo dapat para yan na gagamitin mo normally.
    Oct 2011
    #145
    May separate thread regarding this. Common answer is just make sue the gas station is located in an area which is not prone to flooding (preferably elevated area) and has no history of fooling its customers.
    Try to ask Caltex HQ at Makati City. But Delo 400 plus Baldwin you can easily go 15,000kms. Dami sa Bob isThe Oil Guy forums na mga used oil analysis showing how oil performed after extended drain intervals. 8K-10K miles is common so mga 12k-16K kilometers yun. And the oil is still good.
    Sir, pwede na ba ang Delo Gold or Delo Gold Ultra + Baldwin oil filter for 10,000 OIC or 1 year which ever comes first?
    Go with Delo Gold Ultra.
    May 2009
    #147
    Delo 400 is mineral Type II+ (not type II) as per dvldoc's post sa other thread. special type of Type II.
    Delo 400 is CI4 plus (hindi lang CI4, CH4, etc).
    Delo 400 LE is CJ4 na. eto na yung para sa mga DPF equipped diesels. lower na zinc levels nito. boron, etc na ang mataas ata dito to serve as the antiwear additive.
    It will boil down to what your budget dictates. sabagay mataas din naman kung tutuusin yung TBN ng mobil MX (i think pati rin ata anti-wear). download mo na lang muna yung mga msds/pds nung mga tinatarget mo na oil then compare tapos ilaban mo sa budget mo.
    Dec 2009
    #148
    yung ZDDP pala pag ka under ka nang CI-4 category could range between 5-15% of the total composition of the oil...
    I have read somewhere that Delo Gold ultra 15w40, was specifically made for markets with 3 set of categories as basis for the development, mainly Longevity/ Engine Protection/ heavy duty performance...
    Oct 2011
    #149
    Okay, so ung Delo Gold Ultra, Mobil Delvac MX and Valvoline are all API CI-4 rated. If you are gonna rank them from best to good. Tama ba ito ----> Ultra > Mobil Delvac MX > Valvoline ?
    Oct 2011
    #150
    Yes, will go for Gold Ultra most definitely. mahal daw pag mismo sa Caltex bumili, could someone post here kung saan meron available na dealer or reseller nito? preferably manila area.
    May 2009
    #151
    pwede bang imerge na lang sa kabilang thread......nahihilo nako sa kakalipat. hehehe
    May 2005
    #152
    This what Caltex Philippines sells here:
    Delo Diesel Engine Lubricating Oil - Delo 400, Gold, Silver & Sports - Caltex Philippines
    Delo Gold Multigrade 15W-40 is widely available in most stores. Gold Ultra nad Delo 400 are hard to find.
    #153
    how about gasoline engines ano naman ang maganda and affordable that is safe enough for 10k OCI.
    Oct 2004
    #154
    Base sa recommendation ng isang kaibigan naming engineer from THP na related sa oil industry,- use mineral oil in the first 10,000 Km - 15,000Km para mag sit properly ang mga components ng makina....
    And then shift to semi-synthetic and then fully-synthetic variants....
    15.6K:weathermanf2:
    Yup, ZIC SD5000 (15w-40 multi-grade with CF-4 rating) lang gamit ko with OEM oil filter sa 1k kms break-in oil change ng 2010 strada 4x2 sa casa tapos ZIC 5000 (15w-40 multi-grade with CH-4 rating) with OEM oil filter sa 5k at 10k kms regular oil change sa casa. Used ZIC UP (10w-40 semi-synthetic with CI-4 rating) sa 15k regular oil change with OEM oil filter outside casa and suceeding regular oil change with Fleetguard LF3564 oil filter outside casa. Tahimik at swabe ang engine response using ZIC UP and Fleetguard oil filter.
    Oct 2011
    #155
    Sir, paki post naman kung saan meron available preferably within Manila area itong mga API CI-4 rated na diesel engine oil (mahal kasi sa Caltex and Ace):
    1. Caltex Delo Gold Ultra
    2. Mobil Delvac MX
    3. Valvoline
    Thank you and more power.
    Dec 2009
    #156
    sir retz, usually sa caltex ako bumibili lang delo gold ultra... mapapamahal ka pa kasi kung lilibot ka at hanap mas mura yung natipid mo nagastos din sa pang gas , hehehe..
    mobil delvac nagkalat yan sa banawe area...
    valvoline eh official partner nila ang ace sa distribution at retail... so mostly sa ace nga lang meron, meron din pa onti onti sa labas pero limited ang options in terms of model line up mostly pang motorsiklo makikita sa retail...
    Oct 2011
    #157
    Thank you sir. cge, sadyain ko na lang ang Caltex.
    BTT:
    I have also noticed the Mag 1 All Fleet engine oil for diesel engine it sells for around Php330/Li and when I read the label I'm surprised that it is rated as API CJ-4.
    May 2009
    #158
    meron pa din yung mga naunang delo multigrades sa mga ibang supplies. ultra ang pinakamarami dito ngayon sa amin. unang nagkakaroon ng 400 aside from caltex dito eh yung mga heavy equipment parts centers.
    Sep 2009
    #159
    sige try ko nga delo gold next oil change. dungis kasi ng mga caltex stations dito, katamad din mag DIY.
    tumahimik 4ja1 ko sa HX5. sana ganito lang until the next hundred kms.
    #160
    guys.. pasuggest naman po ng suki supplier ng langis:D
Mineral , semi synthetic or fully synthetic?
