Page 6 of 330 FirstFirst ... 23456789101656106 ... LastLast
Results 101 to 120 of 6586
    Dec 2009
    #101
    Guys this should generally be your rule of thumb when choosing the oil you need so that you get the most protection!!!
    **Amount of Sulfur in Philippine Diesel fuel >500PPM?
    **Is vehicle equipped with Diesel particulate filter?
    ----if sulfur level in fuel is greater than >500PPM choose CI-4
    ----if sulfur level in fuel is less than <50PPM choose CJ-4
    ----if vehicle is equipped with Diesel particulate filter use CJ-4
    ----if vehicle is not equipped with Diesel particulate filter use CI-4
    The main reason why CJ-4 is created is because in other countries
    Sulfur levels in the fuel have been reduced(advancement in diesel fuel)
    And prolong life of particulate filters and catalytic converters
    The TBN ( total base number/ ability to neutralize the acids formed primarily because of high sulfur levels in fuel) is lowered
    the CJ-4 oils have lower phosphorus and other anti-wear additives generally termed as ASH...
    The lower TBN of CJ-4 oils is due to the fact that the fuel has low sulfur and doesn't not need that much acid combating power
    The TBN of CI-4 oils are usually high (10-12) because the fuel that is expected to be used is high in Sulfur.. therefore it contains lots of anti-wear like phosphorus and others to combat the sulfur acid effect....
    As with our current sulfur levels in our diesel fuel CI-4 oils would be a better option...
    ONCE it has been legalized and less than 50PPm of sulfur is enacted then CJ-4 would be option,,,,
    Oct 2011
    #102
    baka sunod ng CJ-4 ay CK-4 na tapos puro less than 50ppm sulfur fuel level na. hindi na applicable sa atin. well, except for euro IV or V on some gas stations.
    Dec 2007
    #103
    Just to clear up something about Isosyn tech that in Caltex Delo gold ultra oil if you notice in it's MSDS it's different then normal group II oil, It's actually classified as Group II plus. And has been proven to protect as well as group III (synthetic) It also has a heavy additive package.
    Solvent dewaxed heavy paraffinic distillate
    Hydrotreated heavy paraffinic distillate
    Solvent refined heavy paraffinic distillate
    KEY PROPERTIES
    SAE Grade 15W-40
    Density at 15°C, kg/L 0.89
    Base No., D2896 mg KOH/g 10.2 Has a good TBN
    Flash Point, °C > 215
    Pour Point, °C < -24
    Sulfated Ash, %m 1.4
    Viscosity, cSt at 40°C 115
    Viscosity, cSt at 100°C 15.1
    Viscosity Index 137 (same as most group III oils) That's why it performs as well as group III
    PERFORMANCE CHARACTERISTICS
    API CI-4, CH-4, CG-4, CF-4, CF, CD, SL
    ACEA E7-08, E5-02
    Cummins CES 20078, 20077, 20076, 20072, 20071
    JASO DH-1
    Mack
    EO-N, EO-M Plus
    MAN M 3275
    MTU Category 2
    Mercedes Benz
    228.3
    Renault
    RLD-2
    Volvo VDS-3
    When you see the Cummins rating you know it's good god oil.
    #104
    too bad, the Zic UP i bought doesnt have Cummins rating.
    Meets API service category CI-4/SL and MB 228.3/229.1 performances.
    Meets ACEA A3/B3/B4.
    though a friend is also using the same oil in his 4g63 powered adventure.
    ^ Mataas naman TBN at yung VI so semi-syn talaga yan CB. Plus CI-4/SL rated yan so very good for both diesel and gas engines (as long as hindi more than 1200ppm yung zinc nga).
    Sep 2011
    #106
    Tama ba yung ginagawa ko kasi delo gold ginagamit ko sa civic ek. 15w40
    Mas ok ba honda lev 10w30?
    Quote Originally Posted by tomboy View Post
    Mas okay sa climate natin and laso for older engines yung w40 viscosity. So better yang Delo Gold na SL rated naman. You don't need to worry about zinc levels since it i just about right at 1200ppm.
    #108
    for cleaning, pwede.
    actually "S" rated din yung delo. so it should be ok.
    Dec 2007
    #109
    Still great oil, Mobil TDT does not have the rating either. They don't meet Cummins due to the Phosphorus content is to low.
    The specs on Mobil which is almost double the cost are not much different.
    Mobil 1 Turbo Diesel Truck 5W-40
    SAE Grade 5W-40
    Viscosity, cSt (ASTM D445)
    * 40ºC 97.9
    * 100ºC 14.5
    Viscosity Index 153
    Phosporous (ASTM D4951) 0.11
    HTHS Viscosity, mPa•s * 150ºC (ASTM D4683) 3.8
    Sulfated Ash, wt% (ASTM D874) 0.95
    Total Base #, mg KOH/g (ASTM D2896) 10.7
    Flash Point, ºC (ASTM D92) 215
    Density * 15.6ºC g/ml (ASTM D4052) 0.85
    #110
    SAE Grade 5W-40
    * 40ºC 97.9
    * 100ºC 14.5
    Viscosity Index 153
    thats great to know dvldoc!
    Sep 2009
    #111
    magkano ba delo gold? pangit kasi ng mga caltex dito.
    Quote Originally Posted by holdencaulfield View Post
    Less than P200 lang yan per liter. Delo Gold Ultra or the delo gold is enough for your ride.
    Quote Originally Posted by speedyfix View Post
    RP is group IV. it's a PAO oil.
    again i doubt mobil 1 even if imported is ester. it's normally a group 3 composed of a mineral base stock with synthetic additives.
    I can't find the file that I read somewhere before but Mobil 1 is PAO oil as well. Hindi nga group V, group IV. Ester based. Anyway, it's good oil. Factory used by BMW, Porsche, MB and other high-end cars. RP and Motul are race inspired as well so talagang maganda din. Pareho pati price maganda.
    Found it. Auto-Rx (Philippines) | About Oil
    Mobil 1 is synthetic. Group IV nga.
    Sep 2009
    #114
    thanks bro!
    btw kaunti pa lang nagagather kong feedback regarding "rev x trekker". so far positive naman mga comments.
    dito sa may petron edsa near monumento ang package nila for change oil nasa 1,100+php only para sa 4ja1 ko. no labor charge. next oil change ko sa kanila naman.
    any feedback on rev x trekker?
    thanks bro!
    My concern with Petron products is that they don't publish the composition of their oil. Viscocity readings lang. Would you buy a product without knowing what's inside. Comparable naman yung price nang Shell Rimula R3 sa Trekker at since maganda yung rating at additives package niya, IMHO, you're better off with Shell Rimula R3, Zic Up 10w40 or Delo Gold Ultra.
    #116
    I used Shell R3 and HX7 but not HX5.
    Shell R3 is good enough for 5,000kms OCI, then swithced to Mobil Delvac MX because I can do 6,000kms on it and oil is still good vs Shell R3.
    Our GS has only 15KKm on the odometer,- and so, I am still using Shell Rimula X R3.... I will be switching to the synthetic variant HX7 in the next couple of oil changes... Curiously, Rimula X R3 has more certifications than the other (synthetic) variants....
    Quote Originally Posted by miko101130 View Post
    pag diesel it will be turning black much faster as compared to gasoline counter part... the color wont really tell you whats the status of the oil.. only an oil analysis will do...
    And others would say that the darker, the better, as the diesel engine oil should be able to float all of the dirt in the engine as part of its cleaning property....
    15.5K:boxing1:
    15.5K:boxing1:
    I believe Shell Rimula R3 X is better than Helix Diesel HX7. If youe want a semi-synthetic that is comparable to the price of HX7 and also synthetic, Top 1 SDO is a better bet or even Delo Sports Semi-syn. Also Zix Up is semi-syn for just P200/liter from one of our tsikot member. Miko101130 sells them.
    Dec 2009
    #118
    Bro, i would recommend that you use Delo gold if you want better protection.... mas mahal nga lang konti pero that translates into something tangible in terms of assurance and protection for your engine...
    among the Big three oil companies here locally, caltex Delo gold is superior ( factually known)...
    petron doesn't publish any data regarding their oils...
    its like when you are buying in the groceries.. you read at the back whats the ingredients contained on the product you are buying..
    Oct 2011
    #119
    mas sulit pala ang delo gold at Php200/Liter kumpara sa Rimula R3 na nasa Php260/Li.
    Same price lang po yan halos if sa mga auto shop na malalaki kayo bibili. Delo Gold and R3 are both CH-4 rated, Delo Gold Ultra yung medyo nasa P190-220 ang CI-4 rated.
Mineral , semi synthetic or fully synthetic?
