Page 11 of 118 FirstFirst ... 7891011121314152161111 ... LastLast
Results 201 to 220 of 2351
    May 2004
    #201
    post na sir DieselDude.
    #202
    Sir, Would you know if there are nozzle tips available in the market for Rover's 200TDI? They only sell whole injectors and someone told me it is only the tips that are needed to be replaced to make it efficient again.
    Thanks for the help
    Sep 2006
    #203
    Thanks for the help
    Rover 200TDIs use two types of injectors, depending on the year model. Bosch has nozzles and service parts for both types, and you don't have to replace the whole injector.
    Most common we see here are the '96 to '98 Rovers, which use the 2.5L 6 cyl. BMW turbodiesel. Do you have the same car?
    Sep 2006
    #204
    Quote Originally Posted by niwde11 View Post
    See copy attached pics of an Isuzu 4JG2 VE rotary injection pump, and it's various accessories.
    Pic 1: Pump mounted on the diesel test stand
    Pic 2: Throttle potentiometer on the left and turbo boost compensator on the right
    Pic 3: Idle-up device and cold idle device
    Pic 4: rpm sensor
    I do hope these pictures help you. And if you have any questions, just ask.
    Bye,
    Dieseldude
    #205
    Quote Originally Posted by Dieseldude View Post
    Thanks for the help
    Vehicle is a Land Rover Discovery 91 model using a 200Tdi 2.5L 4 cylinder engine. Hopefully you guys have a replacement!! I heard there is a Denso nozzle that is similar but hearsay lang siya - I have to research on it pa. Thanks a lot for your reply.
    Sep 2006
    #206
    Bosch nozzles and parts are available for your injector.
    Denso will not have replacements for this.
    #207
    YES!!!!! you have sent me some pretty good news!!!!!! Who can I call or can you give me a figure how much it would cost to have the nozzles changed?
    Sep 2006
    #208
    Quote Originally Posted by edtf View Post
    Our ESI shows that your Discovery used two types of engines which again have two different injectors. Parts are also available for both. Send me the parts numbers inscribed on the injector itself. Or you can bring your car here.
    By the way, why do you want to replace your nozzles?
    You can call me at 411-3711 to 13, ask for Jake.
    #209
    Actually I want to have it checked first to see if it still atomizes the mixture well. Well if it is worn na then I would want to have it replaced na. My disco blows black smoke na and there is a bit of power lag when accelerating. I'll give you a call on monday
    Sep 2006
    #210
    Checking your nozzles will entail dismounting, injector testing, and injector re-installation costs.
    Inspect / replace your air filter element before considering injector repairs as your engine may just be starved of air. This might cure your black smoke and power lag problems.
    Good luck.
    #211
    Good luck.
    Thanks. I just did that yesterday. I'll take note of its performance first. I had the usual change oil changed and had the air filter replaced. It does seem quicker now. I have to have someone else check the smoke
    Sep 2006
    #212
    You can bring your vehicle to our facility for a FREE smoke test. This year is our 30th year anniversary, and we are giving this service FREE of charge... no strings attached.
    #213
    Oh good!! I will take you up on your offer. Thanks a lot for your help
    Oct 2007
    #214
    hi! i have a similar problem... i just had an oil change and installed a new air filter. yes the smoke was minimized but its still visible even at idle engine speed. i'm planning to have the tappets adjusted again. just had it adjusted 15000 kms ago.
    can i avail of that free offer too? where are you located kind sir?
    Sep 2006
    #215
    Quote Originally Posted by sag0 View Post
    You are most welcome. Central Diesel is located at 1176 Quezon Avenue corner Scout Magbanua, near Capitol Medical Center.
    Btw, what is your car?
    Sep 2006
    #216
    See copy-attached picture of blown nozzles. Injectors were pulled off a Starex CRDI.
    #217
    Sir, parang massacred. Bakit naman lumaki ng ganyan yung butas ng nozzle tip?
    Sep 2006
    #218
    Grabe talaga, and this is condition is quite rare. I have an idea on what situations can cause this failure. We are presently conducting a thorough failure analysis with the dealer.
    #219
    wow!! what happened?? can you update us on this? para ma avoid namin yung dahilan ng ganyang klasseng damage
    Oct 2007
    #220
    its an isuzu hilander XTRM...
Diesel Fuel Injection System Help Desk
