Hi Sir Dieseldude
My problem is nag po power loss ung sasakyan ko unti unti decrease nya ng rpm hangang mamatay engine kung hindi ako mag accelerate mamatay engine
(when idle)(Ano kaya ang posibleng reason?)i have checked replace fuel filter(baka barado na) checked the fuel line ok naman wala rin bara(nag palit din ako fuel hose)
(I read from previous post same problem with mine kahit rekta na namamatay bigla engine) Subukan mo mag adjust/increase ng idle speed.
..and also I have the same problem with the recent post bumaba din ang idle ko pag on ko ng Aircon.
(Is there a connection with the first problem?) This is possible...
Pina chek ko sa kilalang mechanic sabi calibration na daw dapat baka daw may problem na sa rotary pump ng Injection Pump is it possible?
(Baka daw kasi) This is also possible....
also please do send me a copy of Pajero's idle and idle-up setting procedure. my email is
yeye6a*yahoo.com.Thank you
Sorry, wala na akong copy ng ganitong procedure. Search mo sa previous posts, baka makita mo. Calling Rion......
