Page 45 of 118 FirstFirst ... 354142434445464748495595 ... LastLast
Results 881 to 900 of 2351
    Sep 2006
    #881
    Quote Originally Posted by jsaure72 View Post
    Ok naman yung switch, could having my injection pump checked help solve this?
    Check the downshift cable. It may be out of adjustment.
    You can also try the "transmissions" forum at Tsikot. You my get better inputs.
    May 2009
    #882
    Sir DieselDude at fellow tsikoteers,
    Ako naman ngayon ang nagkaproblema. My engine is 4D56T..kahapon lang e nagfflicker ung oil pressure light. kapag nirebolusyon e nawawala at kapag hindi inapakan ang accel pedal e nago-"on" ung warning light ng oil pressure. nangyari na ito dati last june 2009 i think but due to low oil levels.
    Pero ngayon iba naman. ok naman ang oil level. i'm using delo gold 15W-30.
    Last oct 2009 eto mga pinagawa ko:
    1. change cyl head gasket
    2. change valve seal
    3. cyl head grinding
    4. change oil and filter
    Eto naman ang mga iniisip ko na checkpoints:
    1. sending unit baka defective
    2. due to oil leaks sa oil cooler lines (bka humihigop hangin kasi matagal ko nang hindi napagawa ung kaunting leaks)
    3. worn engine bearings (crank and cam)
    4. plugged oil filter? ewan ko lang kasi may bypass naman.
    5. plugged oil filter? ewan ko rin.
    Sa mga nakaexperience nito kindly share naman. it would be a great help at least i have some ideas bago ko ipaconfine ang pipip ko. thanks a lot mga sir!
    Sep 2006
    #883
    Try using 15W-40. Mainit na ang panahon ngayon.
    Temporarily remove sending unit, and put in a mechanical pressure guage to see the true oil pressure. If pressure is OK, replace the sending unit.
    2. due to oil leaks sa oil cooler lines (bka humihigop hangin kasi matagal ko nang hindi napagawa ung kaunting leaks) Hindi pwede humigop ng hangin sa oil cooler dahil pressurized ito.
    3. worn engine bearings (crank and cam) Possible cause ito ng low oil pressure. To confirm, you have to check the condition of the crank bearings, and measure bearing to crankshaft oil clearances.
    5. plugged oil filter? ewan ko rin. Hindi siguro pwede ito dahil nabanggit mo na kapapalit mo lang ng oil filter.
    May 2009
    #884
    Salamat sir dieseldude sa reply esp. sa #2 item. nga pala i forgot that i was using delo gold monograde sae 40 pala. last year pa yung 15w-30. my problem is finding a mechanic with complete tools esp ung mechanical oil pressure gage. i'm praying na hindi pa sana pudpod ang mga main bearings. ...
    #885
    sir diesel dude, I just bought a 95' mitsu pajero JDM(surplus) with a 4m40 2.8li engine, A/T tranny, and 4wd. I really dont have any problems with my rig. Yung fuel consumption lang, I only get 6km/li on city driving. Is that normal? or do I need to have it calibrated?
    exhaust is ok, no black or gray or white smoke. Tires are all stock
    Sep 2006
    #886
    6km/L * city is quite high. Check your air intake system, etc.
    City driving cannot be an accurate indication of fuel consumption due to many variables. Try hi-way driving.
    Feb 2010
    #887
    DieselDude,
    Hey got my bighorn fixed, yep had the cable fixed too and now it runs fine. Thank bro
    #888
    If I decide to have it recalibrated, how much will it cost me kaya? thanks
    Quote Originally Posted by Dieseldude View Post
    Sep 2006
    #889
    DieselDude,
    I'm glad. You're welcome.
    Oct 2009
    #890
    sir: need your opinion... may problema ang vacuum system ng 97 hlander ko... noticed na mataas ang idling... had it checked by a mechanic... ang sabi: wala daw suction yun hose connected sa alternator... baka daw barado... ok pa naman ang electrical system ko... di ko alam na may connection sa alternator ang vacuum system ng engine ko... sorry, newbie sa diesel engine kasi...na rerepair pa ba ito? thank you very much!!
    Sep 2006
    #891
    sir: need your opinion... may problema ang vacuum system ng 97 hlander ko... noticed na mataas ang idling... had it checked by a mechanic... ang sabi: wala daw suction yun hose connected sa alternator... baka daw barado... Baka may butas ang hose,or collapsed ang hose, or bake mahina na ang vacuum pump?
    ok pa naman ang electrical system ko... di ko alam na may connection sa alternator ang vacuum system ng engine ko... Vee belt ang pumipihit ng alternator. Alternator naman ang nag da-drive ng vacuum pump. Nakakabit ang vacuum pump sa likod ng altrernator. Pwedeng paghiwalayin sila para ma-check ang vacuum pump.
    sorry, newbie sa diesel engine kasi... No problem, ok lang yan.
    na rerepair pa ba ito? Shempre naman. Kaya dapat ng mechanic mo yan. thank you very much!!
    Dec 2009
    #892
    hi dieseldude. please pm me where your shop is located. i plan to pay a visit when the time comes i need help on my engine. i have innova 2010 d4d.
    Oct 2009
    #893
    Sir: maraming2 salamat sa tulong mo! pa test ko yun vacuum pump this weekend...
    #894
    Sir Dieseldude,
    Good day! tanong ko lang may idea ba kayo kung saan pwede bumili ng may quality, new or 2nd hand isuzu 4BE1 engine or mitsu 4DR7 engine canter? Mga magkano kaya ang presyo nito? Tsaka underchasis narin para sa XLT 10-12 seaters, isuzu elf chasis - flat? plano ko kc mag pa assemble ng xlt auv. salamat bro!
    Sep 2006
    #895
    Quote Originally Posted by ICEage3 View Post
    Sir Dieseldude,
    Sorry, this is not my line.
    #896
    Hi Dieseldude,,,
    Another question...
    Yung mga parts kagaya ng oil filter, fuel filter etc na nabibili sa mga auto supply e original din kaya..? Kayo saan ba kayo bumibili ng mga parts na kagaya nito (casa o auto supply)? Balak ko na kasi magpalit ng fuel filter e pinag-iisipan ko kung sa casa o auto supply ako bibili pati na rin yung oil filter...
    TIA po ulet...
    #897
    Sir Dieseldude,
    Yung knowledge ko po sa diesel engine eh dito ko lang binabasa sa thread. And its very useful.
    Need your advice, first time ko magpapacalibrate and newbie sa diesel engine ang ride ko po is kia besta van r2 2.2.
    Before nga po pala bago ko magdecide to calibrate I replaced the fuel filter and air filter and clean the exhaust pipe. I just don't know the original/oem kasi 2nd hand ko lang sya nabili. Presents of black smoke and lack of power is still present. Nangyari po pala siya after ng top overhaull ko.
    Tanong ko lang po kung ano po yung nozzle pressure? napalinis ko na po sya at naka set sa 100 bars. Me nabasa po kasi sa ibang thread na for r2/rf engine 140 bars po tung nakaset kay sir duskylim po ata yun. Baka kaya i feel loosing power. Applicable bo sa lahat ng makina yung 10 deg at top dead center ang injection pump timing. Medyo confuse lang po kasi meron din po ako nabasa nga dito sa thread na before top dead center.
    Location ko nga po pala eh Sto. Tomas Bats. Medyo malayo po kayo samin kaya advice na lang po..
    more power and thanks po in advance,
    jon2
    Sep 2006
    #898
    Sir Dieseldude,
    Yung knowledge ko po sa diesel engine eh dito ko lang binabasa sa thread. And its very useful. Need your advice, first time ko magpapacalibrate and newbie sa diesel engine ang ride ko po is kia besta van r2 2.2.
    Before nga po pala bago ko magdecide to calibrate I replaced the fuel filter and air filter and clean the exhaust pipe. I just don't know the original/oem kasi 2nd hand ko lang sya nabili. Presents of black smoke and lack of power is still present. Nangyari po pala siya after ng top overhaull ko. Engine or timing malamang ang dahilan dahil lumabas ang problem after the overhaul, at hindi mo naman pinagalaw ang injection pump..
    Tanong ko lang po kung ano po yung nozzle pressure? napalinis ko na po sya at naka set sa 100 bars. Me nabasa po kasi sa ibang thread na for r2/rf engine 140 bars po tung nakaset kay sir duskylim po ata yun. Hindi ako sure sa required nozzle opening pressure. Baka kaya i feel loosing power. Hindi ito ang cause ng low power.
    Applicable ba sa lahat ng makina yung 10 deg at top dead center ang injection pump timing. Hindi. Medyo confuse lang po kasi meron din po ako nabasa nga dito sa thread na before top dead center. Ang timing specs ay nasa workshop manual ng engine mo.
    Ano ba ang make and part number ng injection pump and injectors mo?
    more power and thanks po in advance, jon2
    Sep 2006
    #899
    Quote Originally Posted by erick_214 View Post
    Hi Dieseldude,,,
    Another question.....Yung mga parts kagaya ng oil filter, fuel filter etc na nabibili sa mga auto supply e original din kaya..? Kayo saan ba kayo bumibili ng mga parts na kagaya nito (casa o auto supply)? Balak ko na kasi magpalit ng fuel filter e pinag-iisipan ko kung sa casa o auto supply ako bibili pati na rin yung oil filter...
    TIA po ulet...
    Sa casa ko kinukuha ang filters para sa "modern diesel" ko. Sa Banawe ako bumibili ng filters para sa mga lumang sasakyan ko. Hehehe.
    #900
    Sir Dieseldude,
    Applicable ba sa lahat ng makina yung 10 deg at top dead center ang injection pump timing. Hindi. Medyo confuse lang po kasi meron din po ako nabasa nga dito sa thread na before top dead center. Ang timing specs ay nasa workshop manual ng engine mo. Sir wala kasi akong workshop manual kasi 2nd hand ko lang nabili itong van ko.
    Ano ba ang make and part number ng injection pump and injectors mo? San po ba ito makikita??
    Thanks po ulit...
Diesel Fuel Injection System Help Desk
